Results 1 to 12 of 12
    May 2016
    Lithopolis, OH United States
    Let's say you are recording gameplay footage from Sega CD(or PlayStation) and it features some traditional animated cutscenes like this:
    https://www.youtube.com/watch?v=-Divwuuc2oI
    What should you do? And how can you make it HD for Youtube without quality loss?
  2. DECEASED
    Jun 2009
    Heaven
    First of all, record the video with a FAST && LOSSLESS codec
    (UT Video, HuffYUV, FRAPS, whatever).
    Then you may resize to "HD" with Spline64, Jinc, or perhaps PointSize, which was designed to upscale "pixel art".
    And by HD I mean "anything greater than 640 pixels of height", NOT "cropped to fit a widescreen"
    Not possible. Resizing already means loss of quality, even though often it's possible to minimize it.
    Besides, Youtube always reencodes everything for lower bandwidth consumption :–/
    "Programmers are human-shaped machines that transform alcohol into bugs."
    Mar 2008
    If you'd like an assessment of what might be possible,
    upload a clip from your source
    May 2016
    Here is the file, I uploaded to your site as opposed to Youtube this time.
  5. Funny format. MediaInfo reports it as 640x480, but FFMS2 returns only 256x240.
    Also isn't 60fps overkill ?
    But it nicely shows what happens if you resize pixel art with normal resizers. (didn't really care about size and used crf18 and didn't touch the audio)
    May 2016
    So what would be ideal for me when it comes to those animated cutscenes?
  7. Regarding video format choice: Sorry, don't do ideal. Personally I would use H.265 with 10bit for everything and so a few test encodes and until I known the right crf/bitrate for my usual content.
    Regarding resizer choice: that's your choice, I think one can clearly see the difference between point resize and other resizers. So it's a matter of what you want.
    Cu Selur
    May 2016
    I see. Can I get get the AVISynth or FFMPEG formula for those two at least?
  9. Avisynth scripts I used are:
    ClearAutoloadDirs()
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\LoadDll.dll")
    LoadCPlugin("I:\Hybrid\32bit\AVISYN~1\ffms2.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\RgTools.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\mvtools2.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\masktools2.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\TIVTC.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\MedianBlur2.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\Average.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\GRunT.dll")
    LoadPlugin("I:\Hybrid\32bit\AVISYN~1\nnedi3.dll")
    LoadDLL("I:\Hybrid\32bit\avisynthPlugins\libfftw3f-3.dll")
    Import("I:\Hybrid\32bit\avisynthPlugins\SMDegrain.avsi")
    Import("I:\Hybrid\32bit\avisynthPlugins\Zs_RF_Shared.avsi")
    Import("I:\Hybrid\32bit\avisynthPlugins\Srestore.avsi")
    SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
    # loading source: C:\Users\Selur\Desktop\clips\Test video.avi
    #  color sampling RGB32@8, matrix: pc601, scantyp: progressive, luminance scale: full
    FFVideoSource("C:\Users\Selur\Desktop\clips\TESTVI~1.AVI",cachefile="E:\Temp\avi_865ec41bedf9fa027397c36dee7342f8_853323747_1_0.ffindex",fpsnum=60,colorspace="RGB32")
    # current resolution: 256x240
    # lowering frame rate using srestore
    ConvertToYV24(interlaced=false, matrix="PC.601")
    srestore(frate=7.500,omode=6)
    # cropping
    Crop(0,8,0,-8)# 256x232
    # filtering
    # scaling to 1280x928
    nnedi3_rpow2(rfactor=8,cshift="GaussResize",fwidth=1280,fheight=928)
    # adjust color to YV12
    ConvertToYV12()
    return last
    and:
    ClearAutoloadDirs()
    # removing ghosting
    # cropping
    Crop(0,8,0,-8)# 248x232
    # filtering
    PointResize(1280,928)
    ConvertToYV12()
    return last
    most of the dependencies are due to sRestore and the fact that I don't use the auto-load functionality of Avisynth.
    Cu Selur
  10. DECEASED
    Jun 2009
    Heaven
    Well, I have no idea of why Selur included PointResize() in his tests...
    Maybe he thought PointSize() is just a glorified PointResize()...
    Just a supposition, of course
  11. I never tried PointSize(), haven't encoded pixel art content for ages and back when PointResize was the usual way to keep the pixelation,..
    May 2016
    Thanks for the AVISynth. I guess will record as is but I will give those formulas a shot when I edit my videos. Thanks.
