So I’m running Toast 17, trying to burn a Blu-ray. I decided to make a Toast ISO file out of the disc first (because it takes so long to encode) and then burn said file afterwards (so my BR drive doesn’t have to sit there turned on all day). Toast says the data for the disc comes out to 40.58 GB under Output Summary. The resulting ISO file came out to 52.45 GB, and so when I go to burn it is says my BD DL doesn’t have enough space to fit it. How can I fix this issue, or at least get Toast to give me an honest and accurate file size without losing an entire day encoding an ISO I then can’t use?
Thanks.
Results 1 to 1 of 1
Manageable File Sizes for Editing
By teddybouch in forum Video ConversionReplies: 5Last Post: 27th May 2020, 10:01 -
Giving a video file a higher average bitrate than it actually is?
By Chibi in forum EditingReplies: 4Last Post: 5th Sep 2017, 23:51 -
QUERY: MKV and TS versions of same file reporting different sizes in Toast?
By amckinney in forum MacReplies: 2Last Post: 28th May 2017, 15:56 -
Newbie Questions about file sizes and DVD disc sizes
By pixel_a_ted in forum Authoring (DVD)Replies: 13Last Post: 23rd Sep 2016, 11:44 -
Freemake video file sizes
By dcol in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2016, 17:46
