Hi all,
I got my Diamond VC500 today from the USA. I installed the latest version of virtualdub2 and used Huffyuv to record some sample video and then converted it into x264 while in the program seeing it was unplayable with VLC and WMP without converting it into x264. I am happy with the results. It looks pretty good. Compared to my EZcap it's way, way better.
I have about 15 VHS tapes each about 2 hours long. I have 536GB free on my laptop HDD and I have a 1TB empty external HDD. 40 seconds with Huffyuv used 540mb. The x264 sample took only 17.7MB. Will all the VHS tapes in Huffyuv fit on my laptop HDD or should I record directly onto the external HDD?
In the virtualdub2 settings I have RGB and 8 bit depth selected, will selecting any other option than RGB, the prediction method and say 14 bit depth improve the quality? In the virtualdub2 settings for the video filter I have selected 720 x 480 and I chose PAL_B. I live in Australia. Will selecting a higher resolution capture in a higher resolution and how do I find out the resolution of the source VHS tape? Does choosing a video filter affect the quality?
Is a Huffyuv .avi file supposed to be unplayable with regular media players? The virtualdub2 I installed came with Huffyuv and I installed another Huffyuv codec by copying it to my SysWOW64 folder and right clicking the .ini and installing, maybe it used this codec resulting in the .avi being unplayable? How can I find out which codecs are installed in Windows 7 x64?
How do the other formats like the FFMPEG/x265 lossless compare to Huffyuv in terms of quality? I know Huffyuv is an exact copy of the original bit for bit, is that the same with FFMPEG/x265? Say I want to fit all of these videos onto a 32GB or 64GB usb drive which compression method should I use to cause the least degradation in quality?
My old laptop which I am recording on has old hardware an i7 Q720, 8GB of RAM, 560GB HDD and an ATI HD5650 and is running Windows 7 Pro X64.
Results 1 to 12 of 12
Huffyuv is strictly a 32-bit codec. Do you have a 32-bit version of your media players installed in order to use it?
HuffYUV is preferred to x264 and x265 for capture. Because it uses light compression, it does not tax your system during capture, and because it is lossless HuffYUV is also a decent choice if the video needs to be processed to remove various artifacts or to correct the color. HuffYUV is high-quality because it is lossless but is only playable using a Windows PC. You can always convert from HuffYUV to x264 or x265 after editing and other processing is completed.Last edited by usually_quiet; 9th Oct 2020 at 13:38. Reason: typo, clarity
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I probably used a 32-bit version of Media Player Classic Home Cinema back in the day to play HuffYUV. I forgot some important details. VLC can only use its own codecs. It can't use system-installed codecs. VLC has its own codec for HuffYUV but it is incompatible with encodes produced by the latest version of HuffYUV. I think WMP is restricted to codecs provided by Microsoft.
I think your processor can handle Lagarith if you want to experiment with another lossless codec but VLC and WMP probably won't play that either.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
"Will"...
Good question! I have an ES-15 for passthrough and it certainly steadies and straightens wobbly vertical edges. I'll go out on a limb and say it probably would fix that. It also does improve the picture somewhat. There are some videos of it in action on Youtube, and also here:
http://www.digitalfaq.com/forum/video-capture/11020-how-fix-green.html
I can't advise on the Pioneer. Where are you, East coast or West? -
I recorded in Lagarith and played it in VLC and I found that there is no audio issues anymore but the lines on the bottom and the thick black line on the right side remains. So the whole time the problem with the audio was due to converting it in x264. I will buy the ES-15 and in two weeks when it arrives I will connect it to my VCR and I'll see if it fixes the video issues.
I am on the East coast. I heard on this forum that a similar Pioneer DVR that was made in 2005 was good but I am unsure about the Pioneer DVR 230 it is also made in 2005, but I don't know about the signal quality for VHS. Maybe someone with this Panasonic DVR 230 can comment here on their experience. -
The lines across the bottom are always there with VHS. Hopefully the bends on the sides will be corrected by the ES-15.
If you were on the west coast you could have borrowed my ES-15 to try it. 👍 -
Turns out the seller made a mistake the picture says DMR-ES15 but the ad says DVR-ES15. Hopefully it will be worth it. According to market price they cost around $65 used. The ES15 is worse than the ES10
Yes, no such thing as a DVR-ES15 AFAIK.
$65 is a good price for Oz for a 15. I bought mine for $150 + $40 postage.
You mean "not as good"...
Diamond VC500 blank screen
By RS456 in forum Capturing and VCRReplies: 14Last Post: 30th May 2023, 04:16 -
Diamond vc500 or Not ?
By smartel in forum Capturing and VCRReplies: 1Last Post: 3rd Nov 2019, 03:42 -
Got a new Diamond VC500 but ...
By ksor in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2019, 16:44 -
Diamond VC500 + VirtualDub stopped working after Win 10 update
By lukechen in forum Capturing and VCRReplies: 3Last Post: 18th Mar 2017, 09:07 -
Diamond vc500 partial captures
By clydestoker in forum Capturing and VCRReplies: 1Last Post: 29th Nov 2016, 09:08
