Hi All,
See attachments of two video files I have downloaded.
[Attachment 55332 - Click to enlarge]
[Attachment 55333 - Click to enlarge]
Can someone please break it down to me what would be causing the big difference in file size between these 2? As far as I can see they are both 720. However one of them is almost 3 times as big as the other, despite being of shorter duration. Can someone break this down for me very simply please.
Thanks,
Mathematically
filesize = bitrate x running time
In practice this means, for typical consumer lossy video,
the final size can have a big latitude depending on the settings chosen -
The 1st file is ~2Mbps, the 2nd file is ~8Mbps.
Scott -
And unless the larger file was messed up by whooever encoded it it should look a LOT better. I don't really think it's possible to get high quality 720p video in a <1Gb file using AVC. HEVC, yes.
2Mbps is quite typical for compressed H264 internet video @720p.
The 2nd video is simply less compressed than the first.
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 19:32 -
Editing a 100MB video file turns into 1.5GB file!! How to control size?
By GoodEnough in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2020, 23:27 -
How do I combine a MPV video file and WAV audio file into an AVI?
By robertazimmerman in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2019, 11:47 -
Video Edit - Cutting a section of video from a larger video file
By bpatters69 in forum EditingReplies: 14Last Post: 10th Nov 2017, 11:33 -
how to create a virtual file linked to the a real .avi video file ?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 5th Dec 2015, 09:34
