I can enable AMD FreeSync when using a DisplayPort cable, but not an HDMI cable. Is AMD FreeSync supposed to work with HDMI or is it depended on monitor too?
Results 1 to 9 of 9
AMD FreeSync does work with hdmi,might be a cable issue that you have.
AMD FreeSync is disabled (grayed) in the monitor's setup when using an HDMI cable (tried several).
Sounds like a monitor issue then.
Sorry,i edited my post when i realized you said it worked in dp mode,just refer to my edited statement.
Service claims that the monitor supports FreeSync only with DisplayPort 1.2 and not DisplayPort 1.1 or HDMI.
What Manufacturer and model number is the monitor? This is helpful for other users
Amd b550
By kyrcy in forum ComputerReplies: 25Last Post: 4th Mar 2021, 05:07 -
AMD just sent me a check for $152!
By sophisticles in forum ComputerReplies: 4Last Post: 12th Jun 2020, 07:32 -
AMD Radeon Reinstated?
By Captainfearless in forum Media Center PC / MediaCentersReplies: 5Last Post: 25th May 2019, 15:30 -
Amd ryzen 3 2200g
By kyrcy in forum ComputerReplies: 5Last Post: 25th Feb 2018, 21:29 -
AMD Ryzen 7, Anyone using it?
By sum_guy in forum Video ConversionReplies: 6Last Post: 17th Dec 2017, 04:52
