I'm trying to use the histogram in V Dub 1.9.11 during capture with my GV-USB2 but the V Dub "Levels" function is inoperative with the message "No video levels controls are available with this capture driver".
That doesn't appear to be correct because Video>Capture Filter reveals the Proc Amp on a tab. The problem is, I can't use it live, because opening that tab freezes the incoming video signal. Setting the proc amp controls then becomes a bit convoluted because I have to go out of the proc amp screen to view the live video.
Is there a way of getting "live" proc amp controls with the GV-USB2? I'd be happy to use different capture software is that would mean I'd get access to the live Proc amp.
Thanks! Al
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Leave the preview running in VirtualDub. Open GraphStudio and make a graph with just the Crossbar filter (or maybe capture filter, whichever has the proc amp). Right clip on the crossbar filter and select Properties. Go to the Proc Amp tab. You usually will have a live preview in VirtualDub as you adjust the proc amp.
Terrific Jagabo, that works! I used the capture filter itself. I did have a look at Graphstudio earlier (and Graphedit) but my head started spinning.
Easy now, when you know how. Thanks a lot.
Cheers, Al
Proc Amp Theory and Practice
By Avagadro1 in forum CapturingReplies: 11Last Post: 18th Aug 2020, 21:17 -
Where to fit a proc amp?
By kodec in forum CapturingReplies: 13Last Post: 13th Jun 2018, 00:19 -
I-O Data GV-USB2 NTSC Capture Test
By SameSelf in forum CapturingReplies: 17Last Post: 10th Oct 2017, 19:34 -
using TBC, detailer, proc amp with PAL
By lordsmurf in forum RestorationReplies: 8Last Post: 27th Jul 2016, 10:51 -
Help with I-O Data, GV USB2
By StrangeParoxysm in forum Video Streaming DownloadingReplies: 2Last Post: 3rd Jan 2016, 18:36
