OK, so I've been having some trouble getting optimal video quality from my Simpsons DVD rips using Handbrake but I have made progress. I've been able to reduce combing/interlacing by using the "decomb" feature using the "yadif" setting with the preset set to "default" and interlace detection set at "default" as well as setting the "detelecine" option to "default."
However there is still pronounced juttering in panning shots such as the one in this clip https://youtu.be/nu3eidxD2z4 where the camera pans around the boardroom.
My other settings are:
-30fps Framerate set to Constant Framerate
-Encoder Preset set to "very slow"
-Container is MP4 and is web optimized.
Does anyone know of any further settings/tweaks that can get rid of the pesky judder? This is a US NTSC DVD btw.
Thanks!
				Results 1 to 15 of 15
	If this is from an NTSC DVD, why is that YouTube clip at 25fps? How about an M2V/VOB from the DVD of that same scene?
 Not really relevant, but why upscale to 1080p and why encode the black bars into the video?
	The Simpsons (like many cartoons of that era) has a mix of different frame rates, telecined film plus effects added at 30p or 30i. The best way to deal with that in Handbrake is to deinterlace with Yadif+Bob and encode at twice the frame rate (59.94 fps for NTSC, 50 fps for PAL)
	...spoke too soon. The judder issue in panning shots remains resolved, but another issue is still present: "dancing" or ringing/shimmer around lines. It's pretty prominent in some scenes, such as the screenshot below (especially in Homer's and Lisa's faces). Also uploaded a quick clip to see it in motion https://youtu.be/WfL0_aektUw: it's especially obvious on the dinner plates. Are there any tweaks that can fix this? Thanks!
 My current Handbrake settings are as follows:
 -“Filters” tab: Deinterlace (Yadif+Bob, interlace detection set to “default”)
 -“Video” tab: Framerate is 59.94, at constant framerate with “encoder preset” set to “very slow” setting.
 -Presets: HQ480p 30 Surround
 [Attachment 55438 - Click to enlarge]
	have you tried the encoder tune setting in the video tab ?? - https://www.reddit.com/r/handbrake/comments/ehadxe/settings_to_remove_simpsons_dvd_artifacts/
	Yes, Yadif isn't a great deinterlacer -- though it's the best available in Handbrake. If you're serious you'll have to learn AviSynth.
 To be sure, upload a short (30 second?) sample (this site accepts up to 500 MB) of your source (not reencoded) and we'll take a look at it.
 But many people here have dealt with the Simpsons before you.
	Thank you for your willingness to help! I'd love to upload a 30 sec clip but I'm not sure what you mean by "not re-encoded." Does that mean not converted to an mp4 such as Handbrake does? I thought the point was for you to look at the shimmer/"dancing" around the outlines caused by Handbrake's filters. If you do mean a handbrake clip, I'll upload a 30 second clip of that same shorter clip I uploaded previously, using the same Handbrake settings.
 Thanks!
	We know what the the problem is. The question is how best to avoid it. That depends on the exact nature of the source. Hence a request for a sample of the source. You can extract a short clip with a program like DgIndex. Open a VOB, mark-in, mark-out, File -> Save Project And Demux Video. Upload the resulting M2V file.
	OK here's the (slightly expanded) m2V clip, straight from my DVD. Thanks again.
	Thanks for the code! Wow, I thought it would be as simple as opening AviSynth, importing the clip, pasting in the code and voila it will work. Nope. Seems like it's a bit of a learning curve to learn how/when to add the code to AviSynth (it may involve other programs like FFMPEG?). I'll get there though.
	You open a video using the script as well. I left out the source filter which was:
 MPEG2Source("Test.d2v")
 and then add in the other stuff. You'll have to read the 'Getting Started' sections of the AviSynth website but I believe the best way of learning your way around AviSynth - especially when your sources are DVDs - is to read again and again the docs included in the DGMPGDec package. It includes the stuff you'll need to get started (especially DGIndex and the DGDecode.dll) as well as the best docs in the business. The TFM and TDecimate lines in the script come from the TIVTC IVTC filter which has to be downloaded while the Crop and Resize filters are included in AviSynth.
 A completed script can be opened in VDub/VDub2, MPC-HC and other players, RipBot264, ffmpeg and other encoders.
  Handbrake settingsBy BlurayHD in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2020, 23:29
  Handbrake - Home-Recorded DVDs to MP4s - Best Deinterlace SettingsBy MrExcel in forum Video ConversionReplies: 47Last Post: 24th Feb 2018, 20:27
  Handbrake encoder settingsBy umbala in forum Video ConversionReplies: 10Last Post: 21st Jan 2018, 13:30
  BEST Handbrake settings?By alvis111 in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2017, 21:06
  handbrake encoding settingsBy hokkom in forum Video ConversionReplies: 2Last Post: 21st Dec 2015, 19:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
