Results 1 to 18 of 18
  1. Alright, I'm trying to use QTGMC on a VOB source. The VOB has been run through DGIndex. I can't figure out why this isn't opening in either Virtualdub or Avidemux.
    Virtualdub reports: "File (the avs) does not have a video stream."
    Avidemux reports: "Attempt to open (file) failed!"
    I suspect I'm missing something blatantly obvious, but I'm not very familiar with avisynth usage.
    Here's the contents of the AVS:
    Mpeg2Source("C:\asdfas\VTS_01_2.d2v")
    SetMTMode(5, 8)
    QTGMC( Preset="Slow", SourceMatch=3, Sharpness=1.0, TR2=0, Lossless=2 )
  2. Are you using the correct x86 or x64 matching versions ? e.g. if you have avisynth x64 installed, you should be using vdub2 x64 not x86
  3. Comment out everything but the source line, like this:
    #SetMTMode(5, 8)
    #QTGMC( Preset="Slow", SourceMatch=3, Sharpness=1.0, TR2=0, Lossless=2 )
    Then try to open it in VDub. Does it open? If not, do you have AviSynth installed? To check, make a new AVS with just this one line:
    Version()
    You could also do it like this:
    #Mpeg2Source("C:\asdfas\VTS_01_2.d2v")
    #SetMTMode(5, 8)
    Version()
    Does that open in VDub? Do you have either 16bit or 32bit everything? VDub and AviSynth?
  4. Originally Posted by poisondeathray View Post
    I was using 64 bit Virtualdub 1.10.4, Avisynth 2.6 64 bit. I couldn't find an option for a 64 bit download of Avisynth just now, but I've replaced it with Avisynth+ and I'm getting the same issue.
  5. Originally Posted by manono View Post
    #SetMTMode(5, 8)
    Version()
    #SetMTMode(5, 8)
    Version()
    Commenting out all but the source line didn't work. Version() correctly reports the Avisynth installation.
  6. Did you put the right version of DgDecode.dll in AviSynth's plugins folder? Of import the dll within the script.
    And when using 64 bit AviSynth+ you need to use d2vsource.dll instead because the 64 bit vesion of DgDecode.dll doesn't work correctly.
    http://avisynth.nl/index.php/MPEG2DecPlus
    Edit: TL;DR: Same issue with that one.
    Well, I was using the dgdecode.dll from https://www.videohelp.com/software/DGMPGDec
    I've just tried the version here: http://avisynth.nl/index.php/AviSynth%2B_x64_plugins
    as well as: http://avisynth.nl/index.php/MPEG2DecPlus.
  8. I should have written 32 and 64bit before, not 16 and 32bit. Sorry.
    Anyway, maybe try loading the D2VSource.dll into the script. Did you already try that, as jagabo suggested?
    LoadPlugin("C:\Path\To\d2vsource.dll")
    #SetMTMode(5, 8)
    It might be better to make a fresh D2V file as well.
  9. Originally Posted by manono View Post
    #SetMTMode(5, 8)
    I actually missed that suggestion, but I've tried it now. I copied D2VSource.dll into the folder with the VOB & d2v and I've tried referencing it with and without the path in the avs file. It's still not working.
    Mar 2008
    #SetMTMode(5, 8)
    comment out the mpeg2source and try directshowource directly on one of the VOB's and see if it opens
    for example
    DirectShowSource("c:\path\test.vob")
    AviDemux does not open avs scripts, stick with AvsPmod or Virtualdub for testing
    Are these VOB files you ran through DGindex on the hard drive?
  11. Originally Posted by davexnet View Post
    #SetMTMode(5, 8)
    for example
    Same result with DirectShowSource.
    I just downloaded AvsPmod to test with that, but it crashes with my avisynth.dll *shrug*
    Yes, these files are on my primary hard drive.
  12. Originally Posted by Groundhog View Post
    #SetMTMode(5, 8)
    Post the error message.
    If you're using the newest mpeg2decplus x64, it's been renamed as d2vsource 1.0. The source filter syntax is now D2VSource, not MPEG2Source
    D2VSource("C:\asdfas\VTS_01_2.d2v")
  13. Originally Posted by poisondeathray View Post
    #SetMTMode(5, 8)
    Using D2VSource now. The error is: File "C:\asdfas\script.avs" does not have a video stream.
    Mar 2008
    Download and run avsmeter from the command line to see if any errors come up
    avsmeter64 -avsinfo
    and
    avsmeter -avsinfo
  15. Always post your entire script. Indicate which editor and AviSynth(+) version and their bitness.
    Note that that the script doesn't determine whether you are using 32bit or 64bit AviSyneh. If you open an AviSynth script with a 32 bit editor/encoder you will be using 32 bit AviSynth (if 32 bit AviSynth isn't installed you will get an error), and 32 bit filters. If you open an AviSynth script with a 64 bit editor you will be using 64 bit AviSynth (if 64 AviSynth isn't installed you will get an error) and 64 bit filters. 32 bit Editors can't use 64 bit AviSynth. 64 bit editors can't use 32 bit AviSynth. (Actually they can but it requires special handling that you aren't doing.)
    Did you move your MPG/VOB source file and/or the d2v file after building the d2v? The d2v files requires the original VOB/MPG remain in its original location.
    Open your d2v file in notepad. Does it look something like this:
    DGIndexProjectFile16
    1
    input.mpg
    Stream_Type=1
    MPEG_Type=2
    iDCT_Algorithm=6
    YUVRGB_Scale=1
    Luminance_Filter=0,0
    Clipping=0,0,0,0
    Aspect_Ratio=4:3
    Picture_Size=720x480
    Field_Operation=0
    Frame_Rate=29970 (30000/1001)
    Location=0,0,0,3e2a
    d00 6 0 4096 0 0 0 92 b2 b2 a2 b2 b2 a2
    d00 6 0 4096 1 0 0 92 b2 b2 a2 a2
    d00 6 0 329728 0 0 0 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
    900 6 0 688128 0 0 0 32 32 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
    900 6 0 1075200 0 0 0 32 32 92 b2 b2 a2
    d00 6 0 1224704 0 0 0 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
    900 6 0 1579008 0 0 0 32 32 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
    900 6 0 1961984 0 0 0 32 32 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
    900 6 0 2326528 0 0 0 32 32 92 b2 b2 a2 b2 b2 a2 b2 b2 a2 b2 b2 a2
  16. Alright, it seems to be working now. davexnet, thank you so much for bringing avsmeter to my attention, it helped me solve everything.
    avsmeter revealed that TCPDeliver.dll in my plugins directory (I'm guessing I copied this from my earlier vanilla Avisynth installation, but I don't recall) was 32 bit and getting in the way of loading. I renamed that file.
    QTGMC needed TdeInt in the plugins folder too, which it seems I was missing.
    And I found out that Avisynth+ needs SetFilterMTMode instead of SetMTMode.
    Thank you all for your help
  17. Originally Posted by davexnet View Post
    Please see my post above I found that thread and solved the rest of the issues with the help of avsmeter. Thanks again!
