Hey guys, it's ya boi Lemon comin' at you with yet another FFMpeg hiccup, slap like and hit that bell
So I have some old DV videos that I'd like to convert with FFMpeg just because I wanna git gud with FFMpeg, no other reason. I could very easily accomplish this in VirtualDub but NO
The source videos are 16:9 DAR 29.97 (59.94) interlaced. I want to convert them to x264 square pixel deinterlaced videos (CRF 20 medium) presumably with yadifx2, and I also want to scale them to 1280x720 because for some reason Youtube treats SD videos like shit.
Can anyone help me map out this command? I feel like I'm having to enter the -vf argument three different times in the same command.
In never ffmpeg versions, that would give you a warning that only the last '-vf ..' parameter will be used.I feel like I'm having to enter the -vf argument three different times in the same command.
simply bob deinterlacing with yadif (I would use bwdif instead) and scaling to 1280x720 is this:
(note that depending on your source resolution and PAR you need to scale and letterbox to avoid distortions)Code:-vf yadif=1:1,scale=1280:720
https://www.ffmpeg.org/ffmpeg-all.html is a good starting point in regard of ffmpeg syntax.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Looks like that did it. You know what I was doing wrong? I didn't have a comma. lol
Thanks! -
In case the container or stream aspect ratio of the output are not properly set, you might want to look at:
a. https://www.ffmpeg.org/ffmpeg-all.html#h264_005fmetadata
regarding the "sample_aspect_ratio" to make sure the video stream has the correct aspect ratio.
b. https://www.ffmpeg.org/ffmpeg-all.html#Video-Options
regarding "aspect" to make sure the container has the correct aspect ratio
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
clever FFmpeg-GUI, small FFmpeg UI, fully portable, no installation.
By ProWo in forum Video ConversionReplies: 3357Last Post: 23rd Jan 2026, 04:57 -
(Willing to pay)ffmpeg Need help downloading live stream ffmpeg and rtmp
By grabyea in forum Video Streaming DownloadingReplies: 0Last Post: 10th Apr 2016, 17:54 -
Creating an easy to decode file with FFMPEG
By przewalski in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2015, 09:50 -
[BATCH PROCESSING] how to replace CHOOSE.EXE in a batch routine?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2015, 04:33 -
AVIDemux: Trouble initializing audio device (WinFF trouble too)
By Joker41NAM in forum Newbie / General discussionsReplies: 1Last Post: 1st Nov 2015, 05:12
