I'm calling:
and getCode:"I:\workspace\Hybrid\debug\64bit\ffmpeg.exe" -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p -vsync 0 -f rawvideo - | "I:\workspace\Hybrid\debug\64bit\xvid_encraw.exe" -turbo -bitrate 1500 -pass1 "E:\Temp\test.stats" -w 640 -h 352 -csp i420 -framerate 25.000 -o NUL
as output on the console and the stats file only contains:Code:xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert xvidcore build version: xvid-1.3.7 Bitstream version: 1.3.7 Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC Detected 16 cpus, using 16 threads. -1: key=0, time= 0, len= -5 | type=I, quant= 0, len= 0 Tot: enctime(ms) = 0.00, length(bytes) = 0 Avg: enctime(ms) = -1.00, fps =-1000.00, length(bytes) = -1 N frames: 1 frames, size = 0/ 0
-> any idea what I'm doing wrong? (same happens with '-csp yv12')Code:# XviD 2pass stat file (core version 1.3.7) # Please do not modify this file i 0 0 0 0 0 0
Got an example of a working command line with pipe input?
Cu Selur
Results 1 to 30 of 31
Shortening the calls to:
doesn't help either :/Code:"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f rawvideo - | "I:\Hybrid\64bit\xvid_encraw.exe" -cq 3 -w 640 -h 352 -csp i420 -framerate 25 -o "E:\Temp\test.m4v"
Cu SelurCode:xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert xvidcore build version: xvid-1.3.7 Bitstream version: 1.3.7 Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC Detected 16 cpus, using 16 threads. -1: key=0, time= 0, len= -5 | type=I, quant= 0, len= 0 Tot: enctime(ms) = 0.00, length(bytes) = 0 Avg: enctime(ms) = -1.00, fps =-1000.00, length(bytes) = -1 N frames: 1 frames, size = 0/ 0
users currently on my ignore list: deadrats, Stears555, marcorocchini -
According to this doom9 post, try:
(not tested by me, being busy...)Code:-i stdin
Nope, that does not help:
Cu SelurCode:"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f rawvideo - | "I:\Hybrid\64bit\xvid_encraw.exe" -cq 3 -i stdin -w 640 -h 352 -csp i420 -framerate 25 -o "E:\Temp\test.m4v" xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert Error opening input file stdin
When I call xvid_encraw with -i NUL (to get the version number only), I get the following error:
I hope that's a hint towards the reason...Code:Wrong input format, I want YUV encapsulated in PGM
A "pgmyuv" format for ffmpeg is mentioned, but documentation is sparse.
PS: I asked to get this discussion separated from the original "new version" thread.Last edited by LigH.de; 5th Oct 2020 at 06:51.
May be the pipe format needs to be something else,... ?I hope that's a hint towards the reason...
Explicitly adding '-type 0' to the encraw call doesn't help either.Code:Input options: -i string : input filename (stdin) -type integer : input data type (yuv=0, pgm=1, avi/avs=2) (0) -w integer : frame width ([1.4096]) -h integer : frame height ([1.4096]) -csp string : colorspace of raw input file i420, yv12 (default) -frames integer : number of frames to encode (all)
Discuss in this thread.
Download from https://forum.videohelp.com/threads/386228-Xvid-1-3-5-%28CLI%29 -
@LigH:
here ffmpeg fails:Code:"I:\Hybrid\64bit\ffmpeg.exe" -y -loglevel fatal -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -pix_fmt yuv420p -f pgmyuv - | "I:\Hybrid\64bit\xvid_encraw.exe" -cq 3 -type 1 -w 640 -h 352 -csp i420 -framerate 25 -o "E:\Temp\test.m4v" xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert xvidcore build version: xvid-1.3.7 Bitstream version: 1.3.7 Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC Detected 16 cpus, using 16 threads. Wrong input format, I want YUV encapsulated in PGM Tot: enctime(ms) = 0.00, length(bytes) = 0 Avg: enctime(ms) = -1.00, fps =-1000.00, length(bytes) = -1
looking at 'ffmpeg -formats' there's no pgm format with 'Muxing support' in ffmpeg :/Code:[NULL @ 000002026c727f40] Requested output format 'pgmyuv' is not a suitable output format pipe:: Invalid argument
True, pgmyuv is only a demuxer.
May be necessary to study the sources. -
I hope, studying the source (http://websvn.xvid.org/cvs/viewvc.cgi/trunk/xvidcore/examples/xvid_encraw.c?view=markup) can be avoided,..
I opened a thread over at doom9s about it.
https://forum.doom9.org/showthread.php?t=181894users currently on my ignore list: deadrats, Stears555, marcorocchini -
I guess that xvid_encraw is unable to determine the number of frames of a pipe stream (because it cannot seek to the end of a file and possibly returns a size of 0 bytes), so you may have to add the number of frames explicitly as parameter...
Sadly, adding '-frames 429' didn't help either.
Question: ¿does the problem also happens on Linux or Mac OS
I have just perused the source-code of xvid_encraw and unless I am very mistaken, it doesn't have pipe support on Windows
"Programmers are human-shaped machines that transform alcohol into bugs." -
No clue, at least I haven't tested it since I do most of the encoding I do on Windows.Question: ¿does the problem also happens on Linux or Mac OS
(I guess named pipes might work on Linux, Mac and may be even on Windows, but I'd really like to avoid using them.
Ooops, it seems I didn't express myself clearly
I wrote "pipe", but I actually meant «stdin» =^.^="Programmers are human-shaped machines that transform alcohol into bugs." -
looking at the source of xvid_encraw from http://forum.mediacoderhq.com/viewtopic.php?p=6578&sid=ec823340d2ac72a210714de0c57709d7 it looks like that version might work but it probably needs to be compiled against the current xvid version since the xvid_encraw binary does not seem to work with the current version,.. (or I'm doing something wrong)
Over at squid_80s site (http://members.optusnet.com.au/squid_80/) there is a xvid_encraw64 and xvid64 but I can't get them to work.
Thanks!
got it working somehow a bit:
problem is I only get 2 frames as output (+ that version is really old)Code:| "C:\Users\Selur\Desktop\xvid_test\xvid_encraw.exe" -w 640 -h 352 -framerate 100 -frames 2 -type 0 -o "E:\Temp\test.m4v" xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 xvid [warn]: Single pass defaulting to quant 4.00 xvid [info]: Input is 640 x 352, 100.000fps (100/1), starting from frame 0 xvid [info]: Number of frames to encode: 2 xvid [info]: xvidcore build version: xvid-1.2.0-dev xvid [info]: Bitstream version: 1.2.-127 xvid [info]: Detected CPU flags: ASM MMX MMXEXT SSE SSE2 TSC xvid [info]: Detected 16 cpus, using 16 threads. 1: key=0, time= 2, len= 6 | type=I, quant= 4, len= 16093 -1: key=0, time= 0, len= -5 | type=P, quant= 4, len= 6 Tot: enctime(ms) = 4.00, length(bytes) = 16099 Avg: enctime(ms) = 2.00, fps = 500.00, length(bytes) = 8049 I frames: 1 frames, size = 16093/ 16093, quants = 4 / 4.00 / 4 N frames: 1 frames, size = 6/ 6
(using a frames X with X more than two I only get one)
-> hoping that it works with a modified xvid_encraw.c and a current xvidcore.dll
Ganz leicht ist es nicht
https://forum.doom9.org/showthread.php?p=1925174#post1925174"Programmers are human-shaped machines that transform alcohol into bugs." -
Fortunately Kurtnoise chimed in and fixed the stdin issue of the encraw.exe
https://forum.doom9.org/showthread.php?p=1925197#post1925197"Programmers are human-shaped machines that transform alcohol into bugs." -
Yup, strange thing is I'm pretty sure I had an xvid_encraw back in the days that worked properly with yuv4mpegpipe, but having rawvideo pipe support is good enough.
Hopefully whenever someone again changes something in the code he also adds some error message when there is a parameter that can't be parsed (due to a typo or similar).users currently on my ignore list: deadrats, Stears555, marcorocchini -
Argh,... now that xvid_encraw works MP4Box fails me.
A simple:
gives me:Code:MP4Box -add "E:\Temp\2020-10-07@17_16_39_1610_01.m4v" -tmp "E:\Temp" -new "E:\Output\2020-10-07@17_16_39_1610__02.mp4"
-> I opened an issue for it in the gpac bug tracker (https://github.com/gpac/gpac/issues/1609).Code:[Importer] Error probing E:\Temp\2020-10-07@17_16_39_1610_01.m4v Error importing E:\Temp\2020-10-07@17_16_39_1610_01.m4v: Filter not found for the desired type
Cu Selur
Ps.: mkvmerge doesn't support MPEG-4 ASP raw streams either :/ (https://gitlab.com/mbunkus/mkvtoolnix/-/issues/270)
-> so ffmpeg seems to be the only tools that currently can remux such streams to mkv/mp4Last edited by Selur; 7th Oct 2020 at 14:27.
Yes, that's the reason why MeGUI needs this workaround too: xvid_encraw doesn't create OpenDML AVIs >2GB (and MKV support is marginal, if enabled at all), so it has to create raw MPEG-4 ASP, and then it can't mux it with the optimal tools. Somehow, xvid_encraw is really only a test tool, not a production application.
ideally both should workUpdate: Now works without any -i parameter (and -i stdin is not recognized anymore).
But thanks for looking into it!
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
If you need both, then you will have to convince wiiaboo in the Pull Request on github that he patches the alternative handling back in...
don't really 'need' both just think it's more consistent.
Personally I would prefer '-' for stdin
-> no biggy
Xvid 1.3.5 (CLI)
By LigH.de in forum Video ConversionReplies: 5Last Post: 18th May 2021, 16:17 -
mediainfo cli
By zerobyte01 in forum Newbie / General discussionsReplies: 4Last Post: 20th Jul 2018, 18:41 -
Issues with Xvid Core crashing VirtualDub.
By tjack360 in forum Blu-ray RippingReplies: 5Last Post: 6th Jul 2017, 20:16 -
mkvtoolnix cli to mux files together
By WakaFlakaFlakes in forum Newbie / General discussionsReplies: 4Last Post: 12th May 2017, 17:37 -
x264 CLI so slow
By TeNSoR in forum Newbie / General discussionsReplies: 24Last Post: 18th Feb 2016, 14:11
