Hello folks.
Sometimes I will use my Canon Vixia HV30 as a VHS archiving device. These archives I like to dump to my computer for long-term storage. However, the programs I use -- HDV Split and WinDV in Windows 10 -- are failing me.
1. HDV Split will capture HD footage, but it craps out when I try to introduce a mini-DV cassette with a standard-def, VHS recording on it.
2. I'd try WinDV, but it craps out on me no matter what I'm trying to capture, even HD footage. (I keep getting the error message, "Can't find DV output pin".)
Is Adobe Premiere a solution for this? I have a Mac running Catalina (as an alternative platform), but that will no longer recognize firewire, even through a thunderbolt adaptor.
Anyway, thanks folks.
				Results 1 to 10 of 10
	You haven't indicated whether you are changing the output on your camera from HDV to DV manually or automatically. You should always do it manually before plugging the DV cable into your computer. WinDV only captures standard def, HDV split only captures HDV. Premiere can capture both DV and HDV, but the same rules about manually setting your camera apply.
 You used to have to use both a FW400-800 adapter and a FW800-Thunderbolt adapter to get it to work on a mac. I do not not know if this is still true as there have been several iterations of thunderbolt since I last used it.Last edited by smrpix; 4th Oct 2020 at 16:02.
	The program you want to use is SCLive, also sometimes called Scenalyzer. Andi, the author, put it in the public domain when the demand for capturing DV tapes ramped down.
 www.scenalyzer.com
 While your camcorder will automatically switch between DV and HDV, if it presents itself to your computer as HDV, Scenalyzer (or any other DV capture utility or app) will not connect. Thus, to make things work properly you either need to force the camera into DV mode, if that can be done, or you need to start playing a DV tape before you open Scenalyzer.
	Guys, thank you. I installed Scenalyzer, and it's working just as I need it to.
 I love this site and these fora. I only wish I could help as much as I've been helped.
 I'm going to have questions about capturing digital-8 footage soon, since that's the next thing I need to do.
 Thanks guys!
	Digital 8 is no different than DV, The signal is exactly the same AVI DV, the only difference is the tape stored in.
	Although the interface is different -- at least in my experience it is. I don't know any D-8 cameras with FW800 out? They have FW400, which means I'll need to get a FW400 card, probably on eBay, and hope it works??
	All D8 cameras and all (consumer) DV or HDV cameras, are FW400. 800<-->400 adapters exist, and SHOULD work, but don't always.
	If the adaptors are not too expensive, I shall look into that.
 Thanks much!
 I am FINALLY starting to archive very nostalgic video from over the past 15 years. You guys are awesome.
  Capturing For Archival Purposes - MiniDV/HDVBy ninlive in forum Capturing and VCRReplies: 1Last Post: 23rd Sep 2020, 03:35
  Grabbing mini-DV footage in Windows 10 (Using WinDV and HDV Split)By Kong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Sep 2020, 21:08
  Date/Time Stamp for HDV FootageBy lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 18th Mar 2019, 03:25
  Lost frames/packets when transferring HDV footage from MiniDV via FirewireBy guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 4th Mar 2019, 02:55
  Help Needed to Transfer & Capture HDV/DV Tape FootageBy TheCinematicRose in forum Video ConversionReplies: 5Last Post: 9th Aug 2016, 11:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
