So, I have been performing this project of converting all of my old VHS tapes to DVDs so that I could upgrade to a just DVD/possibly Blu-Ray or 4k Blu Ray supporting trailer. The VHS side of things has been working great, but I am running into problems with the DVD side of things. For the past few days, whenever I try to burn a VOB file to a DVD9, the program WinX DVD Author starts burning, but then it says that the burn process was wrong and ejects my discs, leaving them unusable. I have tried adjusting the write speed, checking my DVD burner, unplugging the DVD drive then plugging it back it, unplugging the power to my laptop and DVD player before shutting down my computer and slowly plugging them back in, and changing what discs I use. I managed to get it to start working for a little bit, but I have no idea what to do. How do I solve this issue, and if I should use different software, how do I easily do so (I'm a beginner and WinX is easy to use, so that is why I used it.) ?
	What computer and what operating system are you using? Windows computers with older operating systems often turn off DMA to DVD drives. That has to be re-enabled, if indeed it has been degraded. The usual solution is to go to device manager, find the IDE connection, and remove it. When Windows next boots it will re-install the drivers and the burner will be fast again.
 This might not be the problem, but since I have seen these more than a dozen times, I know it is the most common cause for what you describe.
  WinX DVD Author doesn't see Bluray DVD ROMBy nofearcavalier in forum Newbie / General discussionsReplies: 3Last Post: 28th Jun 2020, 20:36
  Error Message-WINX DVD AUthorBy sandiec in forum Authoring (DVD)Replies: 2Last Post: 10th Sep 2017, 18:34
  WinX DVD Author crashes on Win 10By andel1 in forum DVD RippingReplies: 10Last Post: 8th Oct 2016, 10:56
  WinX DVD Author CrashesBy Luke_Warm in forum Authoring (DVD)Replies: 0Last Post: 30th Sep 2016, 23:53
  WinX Dvd ripper QBy Syrinx in forum DVD RippingReplies: 2Last Post: 16th Oct 2015, 17:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
