I did some encode jobs with Staxrip and am noticing something weird going on with audio encoded using ffmpeg. The source audio is DTS-HD MA 5.1. I am encoding to AC3 5.1 640. I am noticing crackling audio on some of the encodes. I do not get the same results when I switch the encoder program to Aften for the AC3 encoding. Is there any reason why Aften would produce a better encode than ffmpeg? I thought both adhere to the standard and are considered excellent quality compared to the commercial, paid, Dolby encoders.
	afaik aften was once based on ffmpeg and offered better quality, but ffmpeg was updated more and more and overtook aften (which is nowdays not further developed).
 I would suspect what you are encountering is a bug in StaxRip and you should post your problem in the StaxRip thread (https://forum.videohelp.com/threads/369913-StaxRip) or in the issue tracker over at https://github.com/staxrip/staxrip.
 Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
	Well I know I have tried encoding with both BD Rebuilder (which I thought used Aften for AC3 encoding) and VidCoder which I thought used ffmpeg and I do not really hear any differences there using the same source and encoding parameters for the audio tracks.
  E-AC3 to AC3 conversion using ffmpegBy Nico Darko in forum AudioReplies: 31Last Post: 14th Oct 2025, 23:33
  batch convert DTS to Ac3 using ffmpegBy Mishari in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2022, 17:23
  Is AC3 limited to 20 kHz? Is Spek limited at 20 kHz on AC3?By MLP in forum AudioReplies: 16Last Post: 27th Apr 2020, 12:51
  superior authoring software?By jimfarn916 in forum Authoring (DVD)Replies: 8Last Post: 12th Mar 2017, 09:23
  TrueHD/AC3 question (384 core) need 640 ac3By PatrickBatman in forum Blu-ray RippingReplies: 16Last Post: 31st Dec 2015, 17:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
