I have a (possibly dumb) question for you technically inclined video users. Is it possible to use a 3 input x 1 output HDMI Switch in reverse and use it as a 1 input x 3 output? Instead of (for example) a PS4, a DVD Player and a Cable TV Box plugged into 3 inputs, can you plug the switch into the Cable TV Box and send the output to one of the three HDMI plugs? (Which would then be outputs.) Or are HDMI Switches not simple switches? I would like one connection for my TV, and another one to go to an HDMI Splitter, that sends the signal to two TVs. (I don't plan to use #3.)
I have looked around various websites and this forum for a couple of hours and not found anything that says anything about this. Any advice would be very much appreciated.
Results 1 to 9 of 9
An HDMI port can be a source (for output only) or a sink (for input only) so your idea can't work because HDMI connections are one-way and don't work in the opposite direction.
An HDMI splitter provides multiple outgoing connections from a single input but all the outputs are active. I haven't seen any splitter-type devices that include a switch that allows using only one output at a time.
The closest thing that I have seen to what you want is an HDMI Matrix Switch.Last edited by usually_quiet; 1st Oct 2020 at 20:24.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Yes, there are reversible mechanical HDMI switches. And there are dedicated HDMI selector boxes.
Oh, well... I had hoped to not to have to buy another powered splitter, but I suppose I'll have to. I saw some bi-directional switches, but the look cheap and I have my doubts about them.
Edit: Oops, I didn't see your reply before I posted this, Jagabo. I try searching for those types of switches.
Thanks, guys! -
I have a couple like this (probably a clone). They work okay as a one to two switch, but not the other way around. HDMI splitters and switches are cheap, get what you need.
Edit: I had a 4 port matrix switch. It lasted about a year before it started to flake out, working intermittently. The thing is, HDMI is all or nothing. Either all the connections are solid or you get a severely degrade signal or nothing at all. -
I found something that seems to be a bi-directional mechanical switch like jagabo suggested: https://www.amazon.com/Portta-Switch-Switcher-Bi-Direction-Support/dp/B013SPYFWW
As I recall, you can't A/B or A/B/C on the switch linked above with a live source. You have to switch off the unused devices and wait a while, 10-20 seconds? before switching outputs because the required HDMI handshake protocol. That's what happened with my 4 port matrix switch. It was easier and more reliable to physically swap cables.
Even automatic switches sometimes get confused when switching source, sometimes refusing to switch to the new source as long a the original one is still on. -
I bought this from 'Frys',
http://cirago.com/bhdmswitch2x1w4k.php
*I guess they dont sell it anymore-but sell similar*,
This Cirago *only 2x1*, works as advertised.Yes, no, maybe, I don't know, Can you repeat the question?
S-VHS + HDMI upscaler + HDMI capture?
By Jupit0r in forum Capturing and VCRReplies: 2Last Post: 22nd Aug 2020, 02:00 -
Captions via HDMI
By Binarix000128 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2020, 21:28 -
PC to TV using HDMI
By xray in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2018, 16:44 -
HDMI to old Plasma TV
By Hypersonic1 in forum DVB / IPTVReplies: 30Last Post: 7th Jun 2017, 03:08 -
JVC HR-S7500E plays tape at high speed and VCR switches off
By JohanB in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2015, 09:57
