Hello,
some time ago i started having cracking noise, but than it was fine. Now it started again randomly, no other issues with sound outside Mpc-HC. Currently using version 1.7.13, but the same problem on 1.9.6. I selected - yes delete user setting, when reinstalling, but after reinstall setting remained! I have no idea what is causing it, normalizer is off. Otherwise don't know what could have cause it. Never had similar issue in other players. And i didn't change sound setting at first. But now it should be as it was by default, except not sure about crossfeed . But i tried both variants... I didn't find anything helpful. I am also using SVP Pro, but never had issue in other players with this program. But i prefer mpc-hc. Also this didn't happen ever in mpc-hc. So weird. Dpc latency is very low.
Anyone have idea what is causing this? Thanks!
EDIT: seems like restart fixed it, but last time it was the same and than it started to happen again, will see...
It's SVP. Someone reported the same issue in doom9 support thread IIRC a month or so back.
Feature request for mpc-hc & mpc-be
By babai89 in forum Software PlayingReplies: 5Last Post: 9th Aug 2017, 18:37 -
Media Player Classic / MPC-BE / MPC-HC : differences between them
By devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 17:54 -
[MPC-HC (MPC-BE)] Can't change resizer: same output for each resizer
By rqqt in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2016, 11:07 -
MPC-HC and BD Menus
By jack616 in forum Newbie / General discussionsReplies: 3Last Post: 26th Mar 2016, 13:09 -
3d SBS on MPC-HC/BE
By therock003 in forum Software PlayingReplies: 1Last Post: 7th Feb 2016, 07:56
