1. For MKVToolNix, is there any way to make sure that no errors or warnings occurred in a finished job other than looking at the Warnings / Errors windows? For example, will the program stop muxing and pop up a message letting me know that something happened, or will the status when complete say something besides "Completed OK"? I like to be extra sure nothing bad happened when muxing something and it is a bit annoying to have to look at the two windows constantly when I finish a job.
2. For VCDGear, I have some VCDs that I would like to extract the raw A/V streams from and mux into a MKV file. I was wondering, since I have never worked with VCDs before, if there are any non-intuitive steps to take or settings to alter in order to extract the raw A/V streams.
3. For MPC-BE, I wanted to know how the 3D decoding works. I have a 3D BD, and I installed the optional decoder when I was installing MPC-BE. I ripped said BD into BDMV folder format and it is native "frame packed" (I believe that is the correct term?) format, and when I loaded the folder, it displayed in SBS format. I was wondering if this is Full or Half SBS and if the video I am seeing is encoded, and if it is only being encoded just enough to convert to SBS and is as close to the raw video stream quality wise as possible.
Thanks in advance!
Results 1 to 1 of 1
MadVR, MPC-HC, PotPlayer questions
By holycow in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2020, 22:14 -
Feature request for mpc-hc & mpc-be
By babai89 in forum Software PlayingReplies: 5Last Post: 9th Aug 2017, 19:37 -
Media Player Classic / MPC-BE / MPC-HC : differences between them
By devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 18:54 -
[MPC-HC (MPC-BE)] Can't change resizer: same output for each resizer
By rqqt in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2016, 12:07 -
MKVToolNix
By hardy in forum Newbie / General discussionsReplies: 23Last Post: 9th Nov 2015, 11:57
