I've got problems playing a VCD that I've created, on my DVD player.
I use VirtualDub to capture the AVI and then use TMPGEnc to create the MPEG file. I then use Nero to burn the VCD and also include a Menu.
The VCD plays fine on my PC but when I play it on my DVD, the menu has lines across most of the bottom half and the actual MPEGS are full of block corruptions. The sound seems OK.
I use a Toshiba SD2109 with Princo CD-R (These are the only CD-Rs I've actually got to work at all with my player).
Is this a player compatibilty problem (although other users seem to have no problem with this player and these CD-Rs), a problem with the actual encoding or is it a problem with Nero?
Results 1 to 1 of 1
Problems playing .mkv on a LG BD550
By Pipster2797 in forum Blu-ray RippingReplies: 15Last Post: 9th Jan 2017, 07:53 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 14:16 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 08:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 08:57
