Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
  1. karl
    Sep 2020
    lower hutt new zealand
    DVD Hacks Pioneer DV-373 region code doesnt work - there are no setup or select button on the remote - so i am not sure how whoever wrote this actually did it.
    Has anyone actually done it
    1 user region code comments
    September 21, 2005 Post region code/hack comment
    PostRegion code hack posted by ds, September 21 2005:
    *To convert this player to Multi-Region
    1. Open the drive tray
    2. Press the Setup button on your remote control
    3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
    4. Select the Region option from the menu and change to a specific region or all regions
    To convert this player to Multi-Region if the above does not work
    1. Press the 7 button on your remote control
    2. Press the 6 button on your remote control
    3. Press the Select button on your remote control
    4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
    5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
    6. Press the Setup button on your remote control
    Done!
    Feb 2006
    the setup button is possibly referring to the settings button.
  3. karl
    Sep 2020
    doesn have one of those eithe ron remote
    Feb 2006
    can you post a screenshot of the remote you have ??
  5. karl
    Sep 2020
    see here for what it looks like
    https://www.aliexpress.com/item/32859979163.html
    note my one is a pioneer one unlike what showthough exact same buttons
  6. Member darkknight145's Avatar
    Feb 2007
    Australia
    Possibly press the home button, then select initial settings
  7. karl
    Sep 2020
    tried that no luck there- no option to change region
