I just downloaded a video I was wishing to put onto VCD, but as the track is playing, there is this continuous 'eeeeeeeeeeeeeeeeeeeee' high pitched sound, like an audible dog whistle. I was just wondering if there is any way to get rid of this annoying noise?!? Thanx
search the forum for "hiss" --it's a different noise, but the solution you'll find should work the same wayOriginally Posted by FuCkNuCkLeS
Not to tread on your post but I am also having a similar problem.
But my rip didnt come from a DVD or professinal recording.. Apperntly the person that took this video had the mics to close to the ppl's mouths (or used extremely cheap mics) and I get a screach when people say words that start with S or anything like that.
I searched the forums for "hiss" and none of those would really help to solve my problem. Anyone got any ideas how I can "normalize" my audio? I have to make sure that it doesnt actually touch the video itself, it has to be the same exact length and the people have to say the same words at the same time.. if that makes any sense
thanks
I'm not sure if it will help, but you can try extracting your wav with virtual dub, and then encoding the audio using BeSweet/GUI--look through the different tabs(ssrc, toolame) and there are some options for normalization, and other things that may help.Originally Posted by no1ukn0w
check my previous post here => http://forum.vcdhelp.com/viewtopic.php?t=88969 about the way I remove the hissings...
Bonne chance!!
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
Ripbot sound problem
By ratch3t in forum Blu-ray RippingReplies: 2Last Post: 20th Dec 2008, 08:26 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
