I had been trying to convert the FFMPEG formula to Virtualdub for some time but I have no idea how to do it or even how can convert the formula to fir Virtualdub. I think it would be easier to just use FFMPEG but I do want to edit my videos and stop recording at a certain time. What should I do? Can anyone give e advice on how to handle all of them?
I am trying to figure how to translate FFMPEG into a Virtualdub script.
There is no direct translation from one to the other.
But a basic understanding of the FFmpeg script should be enough to mimic the functionality of the script
in the Virtualdub GUI
A Virtualdub processing settings script is created by first setting up the GUI the way you require
and saving these settings
File/Save Processing Settings
Hope this helps -
I see. I guess I will use both programs then. Thanks.
Incorporate Avisynth Scripts into FFMPEG issues
By rgia in forum Newbie / General discussionsReplies: 43Last Post: 1st Jun 2020, 10:21 -
AviSynth - works in media players, VirtualDub, but not in ffmpeg
By TheArkyTekt in forum EditingReplies: 15Last Post: 4th Dec 2019, 01:43 -
How to use an older avisynth script in ffmpeg
By tyee in forum Video ConversionReplies: 4Last Post: 26th May 2019, 20:25 -
how to tell to Avisynth ---> AUDIO NONE = - an of FFMPEG?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2017, 11:02 -
How to Run Avisynth Script from FFmpeg?
By nothingnew in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2017, 02:03
