My new Samsung Q70T TV will not display VobSubs. I have two older Samsung TVs (6300 & 6500 series) that do display VobSubs. That’s the reason I bought another Samsung when one of the older ones developed a flaw.
I build all my MKV videos the same way, Video+Audio+VobSub+SRT. I add the SRT as a way of preserving the original text. All the VobSubs are created with SubtitleEdit. I build all my MKVs with an old version of MKVMergeGUI (v7.7.0). I have used V49 but it did not make any difference. When I go into ‘Options’ on the video and select ‘Subtitles’ it shows that there are two subtitles present, VobSub being the default since it’s first.
Now the confusing part. On a few (two actually) of the videos only the first subtitle line displays in VobSub format. After that nothing. I then have to select the SRT subs. I have gone through the TV options to see if something need to set but nothing jumps out.
I have searched the WEB looking for answers but have yet found nothing. I don’t know if I’ll find an answer but I know there is a lot of knowledge in these forums so I thought I would throw this out there and perhaps get an insight to a possible solution.
i tried that and got the same results. I even made some changes with my SubtitleEdit settings and no change. I can put the flash drive in my old TVs and the vobSubs will display.
I thought maybe the VOBSub needed to be the only subtitle in order to work correctly.
In the past some TVs needed subtitles to be in a separate file in the same folder with the MKV but I looked at the manual and your TV's built-in media player apparently requires VOBSubs to be multiplexed into the MKV. The trouble shooting guide says "If subtitles are not displayed correctly, check the encoding setting" but It looks like you have already done that. I don't know anything else to try.Ignore list: hello_hello, tried, TechLord, Snoopy329
Photos won't display after rendering
By matonanjin in forum EditingReplies: 5Last Post: 29th Jan 2019, 17:24 -
How do i convert DVD Vobsubs (.idx/.sub) into Bluray Vobsubs?
By Anniguiturve in forum SubtitleReplies: 3Last Post: 9th Aug 2017, 16:23 -
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 22:47 -
Computer won't display avc files
By JustinG7 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2016, 21:22 -
Samsung HT-TX52 display
By wingfan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Jan 2016, 08:21
