Hello everyone,
First time poster here. I run the Nine Inch Nails live recording archive and recently I have come to acquire a lot of master HDV/MiniDV tapes. My expertise with archiving is really with audio and it's about time I start learning about video editing/capturing, especially after acquiring so many tapes. I would usually pass this on to someone else but I believe it's time for me to take a stab.
I run on a Mac Mini (2012, 16GB, i7 - at some point I want to try and get an external GPU to help with editing. I guess that will come later) and will be using firewire to transfer. I am just at a loss where to begin. Even with a playback deck to start off with. Here are some of the decks I have been currently looking at on ebay:
Sony HVR-M10U
Sony HVR-M15U
Sony HVR-1500A (I know it seems probably excessive)
Not sure what units to really be getting. If these smaller (and more affordable) units would do the job of just being able to transfer? Is it really necessary to get something like the 1500A? From what I've read here, the HDV tapes are all binary code, so does it really matter what heads you are using? Or if there is a difference between them in that regard.
I've seen many people in the archiving community encapsulate these in AVI format. Which I intend to do. I will continue to figure out what specs are the best for archiving footage and then also for YouTube/distribution. As right now, having a 25-30GB file being hosted on the archive's site is just too much with the amount of downloads that happen per day.
I'll keep reading on this forum as well and I appreciate any input you have going forward. First off it's figuring out what deck I need to make sure that I have some decent transfers of these recordings.
Thank you!
The link you provided is misleading, M15U is NTSC only not NTSC/PAL. Sony HVR-M15AU is the multisystem one. I'm a proud owner of one it plays both PAL and NTSC tapes, Interlaced and progressive (60i 30p, 50i, 25p, and 24p), HDV, DV and DVCAM in both small and large cassettes, It's all what you ever need for the this type of format.
deciding on laptop to best capture minidv , Hi8 and HDv video tapes
By peterellen in forum Capturing and VCRReplies: 5Last Post: 24th Apr 2020, 05:32 -
High 4:4:4 Predictive@L4 vs. High@L4 4:2:0, for archival purposes
By abolibibelot in forum Video ConversionReplies: 14Last Post: 10th Feb 2020, 02:15 -
Lost frames/packets when transferring HDV footage from MiniDV via Firewire
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 4th Mar 2019, 02:55 -
Issue with Canon HV 40 Capturing BLOWN FIREWIRE?? Dv to HDV?
By ducksalot in forum Capturing and VCRReplies: 11Last Post: 26th Sep 2016, 12:27 -
Any good CD wallets/books for archival purposes
By premiumcapture in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2015, 12:55
