I have a mkv video with chapters. I would like to know if it is possible to split each chapter into their own video without using mkvtoolnix GUI? Is there a command line I could use instead? And to keep the subtitles soft-coded?
In the GUI, set it up to do what you are wanting to do, then go to Multiplexer > Command Line to see the command line it is going to run.
In the "Output" tab select "Split mode": "before chapters". In the field "Chapter numbers" enter "all".
about MKVToolNix
By ujang in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2018, 23:32 -
MKVToolNix Help!
By Alekos65 in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2017, 01:26 -
MKVToolNix
By ThomasCSR in forum Video ConversionReplies: 6Last Post: 14th Jun 2017, 12:19 -
Need help using MKVtoolnix
By Larold in forum SubtitleReplies: 8Last Post: 6th Apr 2016, 08:00 -
MKVToolNix
By hardy in forum Newbie / General discussionsReplies: 23Last Post: 9th Nov 2015, 11:57
