Hi
I have an MP4 file which in windows explorer does not have a LENGTH...and will not play, its 27 Gb in size, is there an easy way to fix this maybe with ffmpeg ?
Results 1 to 14 of 14
try remuxing:
ffmpeg -i "input.mp4" -c copy "output.mp4" -
I tried ffmpeg and various other programs without success
https://files.videohelp.com/u/232580/MediaArea.net_MediaInfo%20-%20X__Hi8%20Video_Keith%20tapes.png
Does this tell us anything ?
ThanksLast edited by Reddwarf4ever; 21st Sep 2020 at 19:17.
Ok I think I knew that, as it won’t play, but can it be fixed ? Only evidence I can see is that there is no length....thanks
Given that MediaInfo says nothing but the name and size -- the file is missing the header info that indicates things like the codecs, frame size, frame rate, running time, etc. That often happens when recordings are terminated improperly (power loss, system crash, etc.) because the header data is usually written last. There are MP4 repair programs that can examine the file along with a similar file from the same device and build a new header (Remo Video Repair, for example).
You can try examining the file with a hex editor. If you find that it's mostly 00 or FF you won't be able to repair the file. The following post has examples of the hex editor view of the first few hundred bytes of a good mp4 file and a bad mp4 file:
https://forum.videohelp.com/threads/397885-Hey-guys-Go-Pro-Hero-3-Corrupted-files-Help...-(#post2588759 -
Used winHex and every single entry is a ZERO....how can it be that bad ?
One of the programs I used created a header file, ( just found it ) but guess that’s a waste of time
Thanks -
LOL, only a pirate would bother trying to fix a file that contained all "00" as data. it's a blank dummy file. steal it from somewhere else.
What’s this talk about a PIRATE file, from aedipuss, I think.......unbelievable how some people’s minds work, takes a pirate to think like a pirate, some might say, but not me �� as another poster said it was from a family Hi8 video file, did a lot of moving back and forth between hard drives, during a recent ‘ tidy up’ think it got corrupted along the way......will have to dig out the original tape and copy it again.....it’s just there are 40 odd tapes and I didn’t number the files, lesson learnt there...
Thanks everyone keep safe and well ��
Oh and thanks to-abolibibelot for pointing out what should have been obvious to aedipuss
Think this thread can be closed now
how get full length and resolution of .mp4 file in windowns details pane?
By enable in forum MediaReplies: 12Last Post: 13th Nov 2019, 09:20 -
Converted MP4 Files Do Not Display Length, Data Rate, Frame Under Windows
By pone44 in forum Video ConversionReplies: 4Last Post: 24th Jun 2019, 01:14 -
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 22:41 -
Problem with different time length MP4 and MTS for same period of filming
By mtn in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2018, 20:59 -
can’t merge gopro .mp4: large final file but same length as individual file
By TonyBoulet in forum EditingReplies: 15Last Post: 30th Aug 2016, 17:09
