Hello folks. Been here before with a related topic, but my problem then was grabbing the footage. It seems now I can, as I purchased an old Canon Vixia HV30 from eBay that Windows can "see". I have two apps: HDV Split and WinDV.
The former captures fine, but saves .M2T files.
The latter "sees" the camera, but gives this error message: "Can't find DV output pin".
I want the files in a more universal standard like, say .MOV or .MP4. But HDV Split does not provide any other options for the file format.
WinDV is not able to grab the video, but it saves files in the more common .AVI format.
Any recommendations or suggestions? Would, e.g., Adobe Premiere help here?
Thanks!
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Since WinDV can't download DV (-AVI) files it appears that your tapes are in HDV format (HDVSplit downloads HDV [a variant of MPEG] files). HDVSplit merely "transfers" the video (and audio) data from the camera to your computer in HDV format, M2T. If you want your video in MP4 or MOV, you'll need to transcode/re-code the M2T files with a separate piece of software, which could be Premiere. There's probably free software that will do it as well.
In my experience, HDV is very easy to edit and, depending on your video editor, I'd suggest you edit in HDV/M2T then render out into MP4 or MOV.
The format that WinDV saves in is DV-AVI, not all that common these days.
WinDV and HDV are no longer 'seeing' my Vixia HV30
By Kong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 17th Jun 2020, 23:16 -
Date/Time Stamp for HDV Footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 18th Mar 2019, 02:25 -
Lost frames/packets when transferring HDV footage from MiniDV via Firewire
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 4th Mar 2019, 01:55 -
Software for windows besides ffmpeg to split multiple videos?
By carlrandall72 in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2018, 08:43 -
Help Needed to Transfer & Capture HDV/DV Tape Footage
By TheCinematicRose in forum Video ConversionReplies: 5Last Post: 9th Aug 2016, 10:42
