I can't change the AC3 bitrate setting.
There is a tab called [Subtitles & Audio], but even if I mess with the [Audio conversion settings] item in it, the audio of the encoded MTS file is only 128kbps. I want 256kbps.
I found a question similar to this one, but it didn't seem to be answered for years. Is this problem solvable? If you cannot solve it, please let me know.
Also, when using this software, it seems that the method is always to convert to PCM and then to AC3. Is there a setting to convert AAC audio directly to AC3 audio?
Thank you.
Results 1 to 1 of 1
In VirtualDub, where is the capture BITRATE setting?
By Avagadro1 in forum Capturing and VCRReplies: 13Last Post: 14th Aug 2020, 12:51 -
AVStoDVD / HC Enc - change 'deadzone' setting?
By Mark777 in forum Authoring (Blu-ray)Replies: 3Last Post: 21st Sep 2019, 19:01 -
multiAVCHD - How to change font size for Audio Subtitle Page ?
By VidGuy82 in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Apr 2019, 11:37 -
Which setting is Variable Bitrate in Handbrake?
By safarian24 in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2019, 07:34 -
Setting fake-interlace flags using MultiAVCHD
By Ravanosh in forum Authoring (Blu-ray)Replies: 0Last Post: 18th Mar 2019, 11:14
