I spent all day looking for a solution to my problem. I have connected an external hard drive to my Sony Bravia television in order to record programs. Since the hard drive is connected with an HDMI cable, I can also connect it to my computer. And that is precisely the problem. My computer recognizes the external hard drive and it contains folders and files. The video files are an M2TS extension. Unfortunately they are not readable as a video file. After searching the internet I found out that the files are encrypted. I have tested several decrypt programs, none of them work. My question is, how the hell can I make those files on the hard drive that are recorded with the Sony television work on my computer?
Results 1 to 11 of 11
you need to get an HDMI Splitter capable of stripping off the copy protection that is installed between the satellite receiver & your PC
see here - https://www.amazon.com/ask/questions/Tx17B6W9PL24AWW/? -
I don't think that will work because, in this case, there is no separate satellite receiver.
If a TV has the ability to make recordings, it records the output from its built-in tuner for free OTA TV received via antenna/satellite dish or, if it accepts a CAM (conditional access module) for a paid TV service, it records the decrypted stream from the CAM. TVs with the ability to make recordings store them on a thumb drive or portable HDD connected to a USB port on the TV. Such recordings are always encrypted and unplayable by anything other than the individual TV that made them. As far as I can recall, nobody has posted a method for decrypting such recordings on VideoHelp.Last edited by usually_quiet; 17th Sep 2020 at 16:13. Reason: left out a word or two
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
As mentioned above, there is no satellite receiver. The wire from the satellite is directly connected to the television. Both the satellite and the external hard drive are both attached to the SMART TV. I've been thinking, wouldn't there be a way to duplicate the image? From the television to the computer ... normally it is the other way around: from the laptop to the television. So that the computer receives the screen from the television. Is there no special program on the internet for this? So I can capture de image from the television on the computer. There must be some way to do that, no?
There is no realistic way to do what you want,
The video connections (HDMI, composite, component, SCART, S-Video, VGA) on TVs are one-way connections. All of the video connections found on recent flatscreen TVs are made to accept video input to the TV. None of them are able to outut video from the TV.
The TV's data connections, USB ports, are the only two-way connections. These can be used for reading from or writing to video files on USB storage devices but the TV's operating system is only able to create encrypted video files.
I guess you could point a camera at the TV and record the screen but that is probably not the solution you were hoping for.Last edited by usually_quiet; 17th Sep 2020 at 19:56. Reason: Correct punctuation
Screen recorders can't record video output from another device (the TV's built-in media player) that is not connected to the computer and cannot be connected to the computer.
[Edit]I'm guessing that the content in that encrypted recording made by busel's TV is not easy to obtain from other sourcesLast edited by usually_quiet; 17th Sep 2020 at 20:39.
It seems the TV software itself is encrypting the recording. Not surprising since it's Sony.
"Only this TV will be able to play the data recorded on the USB HDD that has been registered to this TV.
Recording is supported only for digital TV and radio broadcasts. Recording of data broadcasts is not supported.
Scrambled/encrypted signals cannot be recorded."
Source: https://helpguide.sony.net/tv/haep2/v1/en/03-01_05.html -
It isn't just Sony doing this. I've seen other posts about LG TVs and Samsung TVs with a recording feature that does the same thing.
@busel: For what it's worth, it is often possible to record free terrestrial TV broadcasts and free satellite TV broadcasts with other devices that don't encrypt recordings. Forum members sometimes use PC TV tuners and PVR software or various cheap converter boxes with a recording function to record free TV broadcasts so they can have portable recordings available. This won't help you decrypt the encrypted recordings made by your TV that you already have but it is a solution for the future.Ignore list: hello_hello, tried, TechLord, Snoopy329
Panasonic DMR-BCT74ENK - cannot copy XP recorded footage to external HDD
By guy24s in forum DVD & Blu-ray RecordersReplies: 14Last Post: 15th Jan 2024, 01:20 -
How to Decrypt M2TS files recorded from a Sony Brave Television ext. hdd
By busel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Sep 2020, 15:51 -
decrypt mp4 files application Mpc
By sabair in forum Video ConversionReplies: 0Last Post: 8th Mar 2020, 11:59 -
Decrypt .ts files (AES-128)
By Broken1334 in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jun 2019, 05:25 -
how to decrypt tsv file that recorded from receiver
By Verdax in forum Software PlayingReplies: 5Last Post: 28th Aug 2016, 00:25
