I recently got myself a 4K TV and wanted to re-config my HTPC to take advantage of the TV. I have a number of odd and end questions - hoping someone can help me understand the optimal setup. I use a GTX 1050 TI GPU.
- from what I read MadVR is the way to go with HTPC. I configed MadVR to maximize its performance with Potplayer without any dropped frames. However, if I run the same MadVR settings on MPC-HC, I get a ton of dropped frames. Why is that? Between Potpayer and MPC, is one preferred over the other to work with MadVR?
- a feature on MadVR is up scaling. Since my GPU isn't that good, I can't use 'high' on many of the settings. Is there a way to pass through the task of up-scaling to my TV (Sony 950G)? Or is it still better to upscale using MadVR?
- When i comes to HDR with my GPU/TV, should I use pass through HDR to display, or tone map HDR using pixel shaders?
- to fully take advantage of the TV/MadVR, do I need a better GPU? If so what do you recommend?
Many thanks
MadVR hasn't been updated in a long time because they are busy with their commercial business. That might factor into some issues and newer MPC-HC may change things up depending on your operating system. You might want to look into the video decoder for MPC-HC and try different decoding like d3d11, Nvidia CUVID, or DXVA2 Copy-back, or worse case not using any hardware accelerated decoding as in none. I know MADVR can do passthrough for HDR. Generally you want to use your TV for HDR rather than using MadVR. Better GPU will matter in the future because of 4k or other upscaling algorithms, but hardware acceleration matters a lot for smoother playback.
PotPlayer - How to use MadVR?
By jackuars in forum Software PlayingReplies: 49Last Post: 3rd Dec 2021, 17:20 -
Potplayer + MADVR, is 10-bit Possible?
By vanbrocklin in forum Software PlayingReplies: 1Last Post: 11th Mar 2020, 06:52 -
Saving current frame w/ Potplayer + madVR, not saving madVR effects
By LJay in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2017, 15:14 -
Open MadVR in PotPlayer 32 bit
By loninappleton in forum Software PlayingReplies: 9Last Post: 9th Apr 2017, 23:19 -
MPC BE with madVR Help
By Jackpison in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2017, 03:01
