Hi, I need to convert a mp4 file into a png sequence. According to Vegas it's 84 frames long. When converted to png files with Virtualdub I select all the png files and there are 67 so it's skipping frames. What can I do? Whatever "minimum number of digits" is is set to default of 4. Im not using any filters or anything. CPU is 3950x.
So looks like its variable. The frames are skipping in between not in a big chunk. Im not sure exactly when the frame skips. So if we have 67 frames and it should be 83 someone that's good with numbers may figure it out. Those 16 frames make a difference, the animation feels faster, so I would like to have the 83 frames.Code:MediaInfo says this: Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/isom) File size : 24.3 MiB Duration : 9 s 593 ms Overall bit rate mode : Variable Overall bit rate : 21.3 Mb/s Encoded date : UTC 2020-09-14 13:04:28 Tagged date : UTC 2020-09-14 13:04:28
Also use the "Advanced mode" in the Debug menu to show verbose output (or if you use a CLI version, add the parameter "-f"). Then you should be able to see a range of minimum and maximum frame rates if it is indeed variable. Without this range, the flags would only report that the type of container supports VFR in case it is needed, but it doesn't have to be actually used for this clip.
Converting TTML2+PNG Subtitles to BDN(XML+PNG)
By MounaLafi in forum SubtitleReplies: 6Last Post: 25th Jan 2019, 07:48 -
Womble MPEG Video Wizard changing aspect ratio and skipping frames.
By magnu in forum EditingReplies: 8Last Post: 31st Oct 2018, 03:15 -
Weird Artifacts when extracting video frames to png in ffmpeg
By Blackcero in forum Newbie / General discussionsReplies: 10Last Post: 7th Jul 2018, 11:32 -
BDRebuider skipping frames but ONLY on certain disks
By phaenius in forum Blu-ray RippingReplies: 3Last Post: 26th Jul 2016, 17:30 -
Virtualdub will not import image sequence...now what?
By Ikejohn in forum Newbie / General discussionsReplies: 18Last Post: 23rd Sep 2015, 20:38
