I'm working with a DVD that has multiple episodes packed together in a single VTS sequence, broken up by Title. I've found a way to extract the video and audio streams separated by Title, but I can't find a way to get the subtitles out in the same way. I'd really rather not have to do it manually. Anyone know of a tool that can do that? I've already tried SubExtractor, but no luck there.
PGCDemux can output audio, video, and subs by PGC (Title). The subs will be in SUP format. If that's no good to you, DVDSubEdit can OCR them to SRT.
Also, DVDDecrypter set for IFO Mode (not the default) can extract the VOBs for the various episodes from which you can later demux the subs using SubRip or VobSubConfigure or somesuch. -
That did the trick perfectly. Even looks like it gave me chapter info to boot. Thanks!
When you rip a chapter instead of title-set, is there loss?
By 90sTV in forum Newbie / General discussionsReplies: 2Last Post: 15th Oct 2018, 14:38 -
How can a file with subtitle muxed be smaller than when separate?
By bizzybody in forum SubtitleReplies: 1Last Post: 26th Apr 2018, 18:10 -
Separate dual language subtitle .ass
By skylinekiller in forum SubtitleReplies: 13Last Post: 28th Mar 2018, 17:38 -
Rename files based on chapter title?
By NukeyDoo in forum Newbie / General discussionsReplies: 6Last Post: 6th Dec 2016, 03:48 -
Subtitle Extractor and Converter Script (Drag and Drop)
By Adithya in forum User guidesReplies: 0Last Post: 26th Mar 2016, 11:37
