Hi Editing Folk,
I'm looking to potentially invest in a year's worth of Filmora 9, though I'm undecided due to a couple of (quite basic) issues I can't find solutions to in the trial version. I was wondering whether you guys would be kind enough to advise on the following functions...
* When you have a block of text - a paragraph - displayed via creating a title, how do you go about properly justify-aligning it? As far as I can discern, the last line of a justified-aligned paragraph of text will always look too spaced apart, and, if you try to rectify this by highlighting only that last line and hitting the left-align button, the whole paragraph then becomes left-aligned.
* More basically, I want to add a title above the aforementioned paragraph. I want that title to be centre-aligned and the paragraph to remain justified-aligned, but, similarly to the above issue, highlighting the title and hitting the centre-align button centres the paragraph as well. I additionally want to underline the title, yet, frustratingly, there doesn't appear to be an underline option.
Any advice would be much appreciated![]()
Results 1 to 1 of 1
Filmora capture record - audio only gets stretched or compressed
By Kevin Hall in forum AudioReplies: 10Last Post: 30th Jul 2019, 23:07 -
How do I get good lipsync in Filmora?
By TheoBast in forum EditingReplies: 2Last Post: 19th Feb 2017, 08:48 -
Can Filmora reverse videos without the audio going out of sync?
By BBGFY in forum EditingReplies: 2Last Post: 4th Dec 2016, 04:18 -
Wondershare Filmora...AVOID
By ayoshak in forum Video ConversionReplies: 2Last Post: 15th Jul 2016, 08:25 -
Never heard of this one before . . . (Filmora)
By Seeker47 in forum EditingReplies: 4Last Post: 11th Jun 2016, 06:55
