It's been so long since I burned any downloads to DVD that I have almost forgotten how to do it! I need help, or reminders on what to do.
I have Avidemux, Handbrake, and AVStoDVD installed on my computer.
I have a downloaded file of a film. It is in mpeg-2 TS format. What steps do I need to go through - what re-formatting, and what settings - to create an ISO to burn to disk?
I have copied below the mediainfo on that file. From my attempts so far at previewing, there seem to be two potential issues. One is the video aspect ratio (it should show as 16:9, but displays in preview "squeezed" to 4:3). The other is the audio sync. When I loaded the file into AVStoDVD it showed a -690 delay, and the preview showed it well out of sync.
Do I need to convert the mpeg-2 TS file to something else (in Avidemux or Handbrake?) before trying to create an ISO in AVStoDVD? And what settings do I need to adjust to ensure display and sync are correct?
General
Complete name : D:\Blade Runner_20110722_2307.ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 2.74 GiB
Duration : 1 h 51 min
Overall bit rate : 3 526 kb/s
FileExtension_Invalid : m2ts mts ssif
Video
Menu ID : 6422 (0x1916)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Codec ID : 2
Bit rate mode : Variable
Bit rate : 3 117 kb/s
Maximum bit rate : 15.0 Mb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.301
Stream size : 2.42 GiB (88%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Delay relative to video : -690 ms
Stream size : 204 MiB (7%)
Language : English
Text #1
ID : 5103 (0x13EF)-888
Format : Teletext Subtitle
Language : English
Text #2
Format : DVB Subtitle
Codec ID : 6
Delay relative to video : 5 s 325 ms
Language : English
Menu
List : 5100 (0x13EC) (MPEG Video) / 5101 (0x13ED) (MPEG Audio, English) / 5103 (0x13EF)-888 (Teletext Subtitle, en) / 3845 (0xF05) () / 3847 (0xF07) () / 3848 (0xF08) () / 3849 (0xF09) () / 5104 (0x13F0) (DVB Subtitle, English) / 3840 (0xF00) () / 3841 (0xF01) () / 3842 (0xF02) () / 3843 (0xF03) () / 3844 (0xF04) () / 2319 (0x90F) () / 2320 (0x910) () / 2321 (0x911) () / 2325 (0x915) ()
Language : / English / English / / / / / English
Results 1 to 1 of 1
A/D Transcoding Pass-through or Elgato Video Transfer?
By Obtong in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2020, 21:34 -
Improving laserdisc video transfer
By Arnold_Layne in forum RestorationReplies: 13Last Post: 25th May 2020, 13:48 -
USB2 HDMI Video Capture - Sony HD Video Cam to PC transfer
By pchan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th Feb 2019, 21:16 -
How to transfer minidv video tapes to digital videos
By OldViddy in forum User guidesReplies: 6Last Post: 4th Dec 2016, 09:54 -
Video file damaged after transfer to pc
By Torlon in forum Newbie / General discussionsReplies: 5Last Post: 10th Oct 2016, 19:48
