seems that the latest potplayer versions have included a "potplayer" popup logo in bottom right corner that shows briefly at program launch... is there a way to disable it?
also, is there a way to hide the player frame (navbar, etc.) when the player is in windowed mode? "enable layered window mode" seems to do the trick but it also seems to disable 10-bit video.
thanks!
Results 1 to 14 of 14
1. More users reported this issue, but I don't have this popup window, don't know why, it's the same/latest PotPlayer version, tested even with default settings, may OS is Windows 10 2004 64-bit, using Defender, no other antivirus. First - that popup ad had just users from Asia - with the real ad, not just PotPlayer logo, now users from US, Canada and UK reported it, I'm from EU, it's the only difference I can see, so perhaps EU protects users somehow, GDPR or something?
Is there any user from EU who has this popup ad/logo?
2. This is one of the best PotPlayer options and I think it's the only player with this feature in window mode, auto-hiding the navigation bar, playlist and the title bar, it's in the Preferences - General - Skins - "Auto hide main window skin while video screen is active", for OSC Method I'm using "Direct3D11 Mode".Last edited by Dreamer; 13th Sep 2020 at 08:02.
see this thread - https://forum.videohelp.com/threads/393452-PotPlayer-now-Adware%21
yes, i've used the ""auto hide main window skin while video screen is active" option forever, it's great, but what i meant to ask is if there's a way to autohide when the screen isn't active? as i mentioned this works if you enable layered window mode but then you can't can't output 10-bit video... also, fwiw, if you use direct3d11 mode you can't use madvr from what i can tell.
Originally Posted by october262 -
I don't understand, "autohide when the screen isn't active"? Autohide what exactly and when, if another window is active and PP is inactive?
Here it works with any "Method", disabled, direct3D9/11/openGL, layered.
Could you explain it, or perhaps the screenshot could help. -
when the skin control > on screen control method is set to "enable layered window mode" autohide works in windowed mode even if the player isn't active - the player (skin) controls are auto-hidden even if a movie isn't playing.
when any other sc > osc method is used autohide doesn't work in windowed mode when the payer isn't active - the player (skin) controls are not hidden if a movie isn't playing:
however autohide does work with any sc > osc method when in fullscreen even if the screen isn't active, i.e. even if a movie isn't playing, which is the most important (for me at least) - i would just like a setting where it also worked in windowed mode when set to a mode other than "layered window" because, as mentioned, layered window apparently disables 10-bit or higher output. -
There's not much to do but then I can't do much anyway.
yes, same here, looks like an ad placeholder, i.e. the same location and size others have reported seeing ads:
here are the latest 64 versions, i've rolled back to the 200730 "no ads" version, haven't seen the popup yet, if i do i'll roll back again until i land on a version that doesn't produce a popup, like i had before, just wish i remembered which version it was.
potplyaersetup64-200908.exe
potplayersetup64-200827-beta.exe
potplyaersetup64-200730.exe ********************
potplayersetup64-200730 -ads.exe
Self Edit:
Comment removed
Just realized my comment was misplacedLast edited by gll99; 5th Nov 2020 at 08:20. Reason: Comment accidently written in wrong thread
There's not much to do but then I can't do much anyway. -
vanbrocklin
Strange, navigation bar is auto-hidden here, even if no file is playing, just Playlist is not auto-hidden in this case, but it's possible to disable it with the button, I tried default settings + any OSC Method option except "Disable", you can try also this option:
Perhaps it's GPU/OS related issue, I don't know. I'd post a screenshot, but it would be just a black window - just I have the PotPlayer logo/text in the middle, are you using built-in skin, or is it modified, or is it some option?
BTW my PotPlayer version: 200908 1.7.21291 64-bit, Windows 10 2004 64-bit, Defender.
For others, it's OT, please use this topic for any ad-related issues:
PotPlayer now Adware! - VideoHelp Forum -
I resolved that same issue after some time .. the problem is that Logo while the player is say playing some music in the background or when i had any small small sized player window open while working on something i could never click the part of the screen that Logo showed up and i can't even close it as it disappears in like 3 seconds after opening the player, Anyway... Just go into your PotPlayer installation's folder and Locate the file called PotPlayer.png under and rename it to anything else and close all open PotPlayer and open again and it won't show again. the installation folder of that Logo is by default at "C:\Program Files\DAUM\PotPlayer\Logos" or "C:\Program Files (x86)\DAUM\PotPlayer\Logos"
Good Luck. -
didn't work for me, in fact i deleted the potplayer.png file a long time ago for other reasons, so i don't even have the file on my pc, yet i get the popup, i was thinking that it was embedded in the skin dsf file but was too lazy to extract and confirm....
Originally Posted by Romsryu -
It's not a good idea, old programs have bugs and security problems.
I don't have any popup ads in PotPlayer, but I don't know any other program with such problems.
Another reason for updating are the new features, I know many programs, which have very useful new features, they are adding often.
PotPlayer: disable autoplay next in playlist
By madbucky in forum Software PlayingReplies: 3Last Post: 11th Mar 2023, 23:28 -
Potplayer - Disable Subtitles?
By vanbrocklin in forum Software PlayingReplies: 2Last Post: 28th Dec 2019, 21:34 -
How do I completely disable the playlist in PotPlayer?
By Kizzume in forum Software PlayingReplies: 5Last Post: 14th Sep 2019, 19:20 -
Total disable file history in PotPlayer x64
By savvyguy in forum Software PlayingReplies: 1Last Post: 24th Dec 2018, 13:47 -
How do you disable potplayer icon playback in taskbar
By blackjedi in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2018, 11:11
