I have tried opening the AVI in veedub but I get these errors:
[!] AVI: Index not found or damaged -- reconstructing via file scan.
[!] AVI: Invalid chunk detected at 96009530. Enabling aggressive recovery
mode.
[!] AVI: Keyframe flag reconstruction was not specified in open options and
the video stream is not a known keyframe-only type. Seeking in the video
stream may be extremely slow.
I am trying to convert AVI ( car security system video) to MP4 so I can open them in davinci resolve 16 to edit.
I have tried using VLC it converts the video but loses the sound.
Windows 10 PC
I attached a screen shot. I dont know whow to use Media thing, sorry If I have done it wrong. Is that the info youre after?
I just tried Veedub 2, there were no errors, but nothing actually opened just 2 grey squares where the video should be. I dont know why this is so complicated. Am I using the wrong programs. I just want to be able to put the Camera files into Davinci or Lightworks so I can edit/cut them etc.
ok I got it to convert WITH audio in VLC by selecting the same settings as above ie 8000hz, 16 bits, 1 channel. It plays with sound but when I put it into davinci there is no audio,Last edited by Liesh; 12th Sep 2020 at 22:40.
Because VirtualDub uses VFW -- which hasn't been updated in 20+ years. No version of Windows ships with a VFW AVC decoder, you have to install one (VirtualDub2 has one built in). AVC is almost never used in an AVI container. VFW is not meant for out-of-order codecs. Special kludges (known as the VirtualDub Hack, or Packed-Bitstream) are used to package OoO codecs in AVI
And, of course, starting with a corrupt AVI file isn't helping matters.
Since you've been able to convert with VLC -- just change the audio sampling rate (and maybe audio codec) while converting to something your editor can deal with. And use MOV instead of MP4 for PCM audio (WAV in VLC). Most programs don't support PCM in MP4. -
AVC (PAL) is the only option I have NTSC doesnt work here ( just flickers up and down) To put it into davinci I have to convert to MP4 in VLC then put it into Wavepad to make a copy of the sound and put them both in Davinci. There is no option to make WAV or MOV in VLC.
all the files have the same error when put directly into Veedub, and dont open in Veedub to ( just grey empty square)
If they are truely corrupt files, its how they are recording. I have no idea, there isnt many settings in the recorder itself. I can only change the bitrate from low, medium and high.
How to open a .7z file?
By gastrof in forum Newbie / General discussionsReplies: 11Last Post: 7th Mar 2018, 20:42 -
VirtualDub / VeeDub
By Alcus in forum Video ConversionReplies: 3Last Post: 18th Feb 2018, 13:11 -
why VirtualDub64 don't open the same .AVS script that virtualdub32 open?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2017, 05:04 -
vReveal Cannot Open AVI
By box-turtle in forum Newbie / General discussionsReplies: 7Last Post: 28th Aug 2016, 15:39 -
Open DebugMode signpost avi into 64-bit encoder??
By avreader1 in forum Video ConversionReplies: 0Last Post: 7th Aug 2016, 02:04
