Good health to you. Immediately I apologize for translating through machine translation services.
I've been chasing codecs with maximum lossless compression ratio lately. Kind of found this MSU and YULS but I have no idea how to use and encode videos in them. Can anyone help me?
If you describe why I'm chasing: my video library has grown so much that I started thinking about backups ... But terabytes are expensive, so I'm looking for ways to compress everything to the maximum, even if recovery in case of a crash will cost a lot of CPU time (unzipping-decoding ).
I would be grateful to everyone who gives their opinion, thank you!
Probably you shouldn't bother with this -
If you're starting with lossy compressed videos, lossless video compression will increase the filesize, usually ~5-20x. The "lossless" video compression refers to decoded, uncompressed video
If you're starting with highly compressed video (eg. typical use settings for x264, x265), archiving them with 7-zip, winrar etc.. will increase the filesize slightly too. Only lightly compressed video, such as DV, MPEG2 can benefit from a small% compression for archival software -
As stated if you are not working with lossless videos already, then this is counterproductive. Lossless video is usually around 25GB per 1hr of 480p, and around 100GB per hour of 1080p (YV12 or YUY2). If you have files that are less than 25GB per hour of 1080p, then your video is probably lossy.
That being said I was never impressed with MSU and don't use it. YULS is probably the best lossless codec for 480p/576p content but it is really really slow and not worth it. I only use FFV1 for best compression with practical encoding speed. I use Lagarith if my computer is not powerful enough.
AV1 Comparison from MSU
By DmitriyK in forum Latest Video NewsReplies: 0Last Post: 13th Apr 2019, 11:58 -
MSU Video Codecs Comparison 2019 - CALL FOR CODECS
By DmitriyK in forum Latest Video NewsReplies: 0Last Post: 19th Feb 2019, 02:25 -
Any help please with MSU subtitler remover
By foldbck123 in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2018, 05:47 -
MSU Color Enhancement codec
By kalemvar1 in forum Video ConversionReplies: 3Last Post: 12th Nov 2017, 07:31 -
The first HEVC codecs comparison by MSU Laboratory
By Stears555 in forum Video ConversionReplies: 22Last Post: 20th Nov 2015, 21:53
