Just recently got a Pinnacle Movieboard capture card. I installed it in my mobo and then the driver Win764bit from Pinnacle's website (since this was the latest, from 2012), everything worked fine (shown as mutlimedia controller in device manager) until I tried to capture with it. Virtualdub freezed. Also tried AMCap, this caused BSOD.
How is it possible to work this capture card under Win10 without error? Even it's possible to work?
If you used the original Virtualdub, try Virtualdub2 instead. Virtualdub2 is supposed to workwith Windows 10 and is still being maintained.
BrightEye 75 VS Pinnacle 500-USB
By dellsam34 in forum Capturing and VCRReplies: 6Last Post: 9th Aug 2020, 21:09 -
Dual boot Win10 32 bit with Win10 64 bit
By bevills1 in forum ComputerReplies: 15Last Post: 9th Apr 2018, 17:59 -
Paint.net On Win10
By budwzr in forum EditingReplies: 0Last Post: 8th Feb 2018, 22:31 -
Win10 31.january update
By Bernix in forum ComputerReplies: 0Last Post: 31st Jan 2018, 15:27 -
Win10 or BIOS Problem
By bevills1 in forum ComputerReplies: 21Last Post: 13th Nov 2016, 13:01
