Hello all,
As the title suggests I am after advice on how to change an MKV file audio component from DTS-MA to AC3
My new LG CX77 OLED doesnt support DTS-MA..
I'm not familiar at all with with how to use programs with scripts either unfortunately.
Thanks,
ZG
There are different ways to do it.
The most straight forward solution would be StaxRip
Here a quick picture guide:
1. Open your video -> Select "Single File"
[Attachment 54877 - Click to enlarge]
(if a window opens with asking you to install a dependency, install it, then close the window)
2. (1) Select your video output - (2) Set the Video Codec to "Copy/Mux"
[Attachment 54878 - Click to enlarge]
3. (1) Click on the Audio Codec - (2) Set it to AC3
[Attachment 54879 - Click to enlarge]
You can repeat Step 3 for the other Audio Track if you have one.
If you don't like this approach, or if you are not on Windows, you can try ffmpeg:
Code:ffmpeg -i yourvideo.mkv -c:v copy -c:a ac3 -b:a 640k out.mkv
Popcorn Audio Converter developed by a member of Popcorn Network Media Tank forum
Convert mkv with DTS HD MA to mkv with DTS core - Mac user
By bardian in forum MacReplies: 3Last Post: 9th Apr 2020, 15:30 -
Best way to add mkv and ac3 or dts in Adobe Premiere Pro
By m00511 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jan 2020, 20:14 -
Can DTS 5.1 and AC3 5.1 exist in the same MKV?
By JBC in forum AudioReplies: 7Last Post: 7th Jan 2018, 08:44 -
Mkv convert dts sound into ac3
By fits79 in forum AudioReplies: 5Last Post: 5th Jan 2017, 22:41 -
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 24Last Post: 7th Jul 2016, 07:17
