I'm getting the following error:
mt_lutxy does not have a named argument "use_expr"
I'm using Avisynth 32 bit version. Went to github and downloaded the most recent mvtools2, and this is the error I'm getting. Please advise if you can help.
Thanks.
Results 1 to 27 of 27
Google led me here:
https://forum.videohelp.com/threads/390035-Error-when-using-QTGMC-v3-361-with-Masktool...ng-mt_makediff
Some comments in there may address this.Want my help? Ask here! (not via PM!)
Yeah but Smurfy, I already went to that page before you posted it here and I'm still getting the same error. Do you have Smdegrain in your collection? Is it possible for you to share, along with the dependencies please? I"ve tried EVERYTHING to get it back. I had it all and lost it trying to update stuff just to get another filter which I no longer need (I think) anyway.
Yup. It seems like I'm totally screwed. I should have listened to TLC and not gone chasing waterfalls.
Smurfy or anyone...if there's anything you can do to help this cranky old fart, it would really be appreciated. -
I've been doing lots of Avisynth lately. Backlog of projects, saved the "best" (hardest) for last.
I just installed "SMDegrain.avsi" last week, so it must have come from an official repo.
http://avisynth.nl/index.php/SMDegrain
If you're looking for an old version, I don't appear to have anything. I may have some stuff on a backup VM of an old computer, but not where I can boot it right now.Want my help? Ask here! (not via PM!)
Jagabo, I downloaded the most recent release posted there, and now instead of getting this error:
Code:mt_lutxy does not have a named argument "use_expr"
Code:mt_lut does not have a named argument "use_expr"
Please advise. -
Maybe you need an updated Zs_RF_Shared.avsi.
https://github.com/realfinder/AVS-Stuff/raw/master/avs%202.5%20and%20up/Zs_RF_Shared.avsi -
Ok, I have no idea what that is, can you please clarify? What am I supposed to do with it, save it as an avsi in my plug-in folders and everything will work out?
And if so, what name am I saving it as?
Thanks. -
I totally messed up everything. Chasing after a filter that I ultimately did not need, I wound up making "updates" which wound up ruining MOST OF MY WONDERFUL FILTERS. At this point, I'm thinking about totally removing Avisynth and re-installing everything from scratch. What do you think?
Too late now but... I usually back up my plugins folder before making changes.
If all you've been doing is adding/removing filters in the plugins folder there's no need reinstall AviSynth. You can just move/delete the plugins out of the folder. I think the only plugins that come with AviSynth (2.6) are colors_rgb.avsi, DirectShowSource.dll, and TCPDeliver.dll.
btw. if you are using Avisynth+ you could add 'ClearAutoloadDirs()' at the top of your script to make sure auto-loading is disabled.
This way only filters and scripts that are explicitly loaded/imported in the script will be used.
Yes, this is a bit more troublesome when using scripts that reply on tons of filters, but on the other hand it's way easier to identify problems with filters.
Here's an example on what a script using SMDegrain looks like in Hybrid:
Code:ClearAutoloadDirs() LoadCPlugin("I:\Hybrid\32bit\AVISYN~1\ffms2.dll") LoadPlugin("I:\Hybrid\32bit\AVISYN~1\mvtools2.dll") LoadPlugin("I:\Hybrid\32bit\AVISYN~1\masktools2.dll") LoadPlugin("I:\Hybrid\32bit\AVISYN~1\MedianBlur2.dll") Import("I:\Hybrid\32bit\avisynthPlugins\SMDegrain.avsi") Import("I:\Hybrid\32bit\avisynthPlugins\Zs_RF_Shared.avsi") SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) # loading source: F:\TestClips&Co\files\test.avi # color sampling YV12@8, matrix: bt601, scantyp: progressive, luminance scale: limited FFVideoSource("F:\TESTCL~1\files\test.avi",cachefile="E:\Temp\avi_078c37f69bb356e7b5fa040c71584c40_853323747_1_0.ffindex",fpsnum=25,colorspace="YV12") # current resolution: 640x352 # filtering # grain handling SMDegrain(interlaced=false) PreFetch(8) return last
users currently on my ignore list: deadrats, Stears555 -
I never needed to do this before, why should I do it now? All I need is for my filters to work. Why is it that despite my downloading so-called "current" filters, they're NOT WORKING????? -
These developers need to get their shit together with their updates, that's all it boils down to.
Sorry, I tried to show a way to have more control over what happens.
No clue what you call 'current' filters and where you got your scripts from,..
I got my scripts from https://github.com/realfinder/AVS-Stuff and both Avisynth+ 32bit and 64bit work fine with the filters I use.
So, again sorry for trying to help.users currently on my ignore list: deadrats, Stears555 -
a filter is an avisynth filter.
Current. Filter.
Need further clarification or were you just purposely playing dumb with me?
So, again sorry for trying to help -
How about shit just WORKS LIKE IT'S SUPPOSED TO without me having to run around like an ******* downloading this and downloading that?
You know, for a website called videohelp.com most of you are pretty useless. Alot of people come here to show their credentials and spew jargon, but very little help here takes place.
No clue what you took or didn't take,...
I packed the filters and scripts I use atm. when using SMDegrain with 32bit Avisynth, may be that helps may be it doesn't.
If those scripts and filters don't work for you it's because of your setup, but since I do not seem to want to understand stuff, but seem to be more interested to scream at folks I'll leave you alone.
Good luck with your endeavor.
Cu Selurusers currently on my ignore list: deadrats, Stears555 -
http://avisynth.nl/index.php/RgTools/RemoveGrain has multiple modes and the error means that the Library that provides Removegrain which you have in your autoload folder doesn't support this mode.
RgTools (https://github.com/pinterf/RgTools/releases/tag/1.0) is used nowadays as source for Removegrain.
Depending on your SMDegrain settings more than the default filters are needed.
I again attached the files I use.users currently on my ignore list: deadrats, Stears555 -
Yeah I'm still getting the same error. You were helpful with attempting to share your filters, so I do thank you for that.
smdegrain issue
By Betelman in forum RestorationReplies: 2Last Post: 24th Jun 2020, 03:57 -
SMDegrain script error
By JoeSchmo999 in forum RestorationReplies: 4Last Post: 14th Apr 2020, 17:23 -
smdegrain and MCTemporalDenoise errors
By Betelman in forum RestorationReplies: 15Last Post: 17th May 2019, 00:03 -
What Masktools Version should I use for SMDegrain Mod 3.1.2d?
By VideoFanatic in forum Video ConversionReplies: 4Last Post: 30th Mar 2018, 21:37 -
Problems Demuxing, Remuxing and Encoding AVIs. Also MeGUI problems.
By VideoFanatic in forum RestorationReplies: 1Last Post: 10th Feb 2016, 03:30
