I'm posting in the Newbies forum.... after some long time away from the forum ... because I am still very much a newbie.
Here's my problem. I have a set of 3 episodes of a BBC TV documentary (which is no longer on i-Player). I recorded them some time ago, and I now cannot remember what software I used. I have them saved as mp4 files. Each lasts about an hour. They play perfectly well in VLC on computer. I used AVStoDVD to create an ISO of all three episodes, and burned them to a single DVD.
Just recently I played the DVD. The first two episodes played OK. The third one started fine.... and the video is good all through ....but the audio goes progressively out of sync. By the end of the hour it is so far out as to be unrecognisable. I don't know whether plus or minus, but the difference is big - trying 'j' and'k' on VLC doesn't bring it into sync.
I had saved the ISO file, so I checked that by playing it using VLC. And the ISO shows the same problem.
So the sync problem has somehow happened during the processing of the mp4 file(s) by AVStoDVD to create the ISO. The odd thing is that it only affected the third of the three mp4 files; and it is not a constant sync-delay (which I think I know how to fix by re-doing the conversion and using the AviSynth tab?). But for this progressive and eventually massive loss of sync, how do I put it right?
If more specific technical details of the video and sound tracks of the mp4 file are needed, I can get them from the AVStoDVD project file. [EDIT and update... now added in as below]. I'd need more guidance if asked to provide log files or other such info.
The details of the MP4 file of the episode which goes out of sync are shown as follows in the AVStoDVD screen:
video: AVC - 1604kbps - 1280x720 - DAR16:9 - 50fps(CFR) - Progressive - 59:05minutes - 177236frames
audio: AAC LC - 132kbps - CBR -2ch - 44100Hz - 59:04minutes - (0ms delay) - UN - Internal
Results 1 to 15 of 15
Thanks, ProWo.... those two software programs are new to me. But I have followed your advice.
The sync problem is there in the extracted mpg file. Here is the mediainfo:
General
Complete name : C:\Users\Brian Admin\Videos\Title_3.mpg
Format : MPEG-PS
File size : 1.44 GiB
Duration : 59 min 4 s
Overall bit rate : 3 494 kb/s
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Bit rate mode : Variable
Bit rate : 3 232 kb/s
Maximum bit rate : 9 000 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.312
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 1.33 GiB (93%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Muxing mode : DVD-Video
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 81.1 MiB (5%)
Service kind : Complete Main
I don't really understand any of this stuff! I hope you do, and can spot the problem. More important, I'd really appreciate advice on how to fix it...
Is the "frame rate" an issue? The video and audio details show a difference.
If it helps, I have Avidemux and Handbrake already installed on my computer, as well as AVStoDVD - but I don't claim to be expert with any of them: I usually just rely on their default settings. Happy to take your advice. -
You say that the third MP4 file plays fine, but the portion of the DVD authored from that file has an audio sync problem. One possibility is that the other two MP4s are 24 fps, and the third one is 25 fps (or the other way around). Use Mediainfo to look at each of the MP4 files, one at a time, and write down the FPS for each one.
If you still want/need a DVD of the episodes, probably the easiest thing to do would be to re-author the three MP4s to a new DVD. If you are worried about having the problem appear again, you could burn the result to a DVD re-writeable. I always do this to check my work, so I don't waste a lot of media, especially now that my supply of quality media is limited to what I have on my shelf.Last edited by johnmeyer; 11th Sep 2020 at 19:28. Reason: typo
Audio and video track are of equal length. I think they are muxed wrong. Load the ifo file of the third episode in pgcdemux and save video and audio track separately. Then re-mux them with imagompeg muxer.
Well, ProWo.... I had high hopes.
I did exactly as you suggested. Used pgcdemux and saved separate video and audio files. Then used imagompeg muxer to create a new mpeg file. Then I played it using vlc, to check it.
The sync problem remains. At the start of the mpg, the video and audio are in sync. By about 40 minutes in, the audio is a long way ahead (I'd reckon maybe 5-6 seconds) of the video image.
So - whatever the problem is, that hasn't solved it! Any more alternatives to try?
Incidentally - thanks, johnmeyer, for your response. I haven't yet tried re-recording all three MP4s. But I already know that the first two convert and record perfectly happily on to DVD. The third episode plays in perfect sync as an MP4 when played via VLC. But when converted (by AVStoDVD) for creating a DVD ISO image - or now when the tracks are split and re-muxed as ProWo suggested - the sync problem arises. I'm not wasting DVDs, because I normally create an ISO first, and check that with VLC before burning to a disk. And - as mentioned, when I check the ISO, the sync problem shows up (so I don't burn it to disk....).Last edited by br1anstorm; 12th Sep 2020 at 18:28.
Hello davexnet
I have this AVStoDVD log file from a few days ago. This was an attempt to create a new ISO when I found that the DVD I had made a year or so ago had the sync problem.
This attempt included all three episodes of the TV programme, not just the problematic one (which is Episode 3). I checked the ISO before burning another disk - and found that it, too, still had the sync problem. Here are the details - I hope you can interpret them:
<10/09/2020 20:01:19>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 3
DVD Size: 4449/4450 MB (100%)
DVD Output Setup: ISO UDF Image
DVD Label: A Dangerous Dynasty
DVD Menu: Static Menu
Output Folder: C:\Users\Brian Admin\Videos
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 0
FPS Hard Conversion: 0
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
Video BitRate Min: 2500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: Slimtype DVD A DS8A8SH KS21
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Execute with Elevated Privileges: 1
Unload ActiveMovie Library: 1
Adjust DirectShow Filters at runtime: 1
Save General Settings: 0
SYSTEM INFO
Processor Name: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Operating System: Windows 7 - Service Pack 1 (6.1.7601) 64 bit
User has Admin Rights: YES
Running with Elevated Privileges: YES
Available Output Disc Space: 15 GB
AviSynth is installed: YES (release 2.6.0)
LAV Filters is installed: YES (release 0.68.0)
ffdshow is installed: NO
CODECS REPORT
H.264/AVC: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
Xvid: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
DivX 4/5/6: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
Other MPG4: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
DV: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
MPEG1: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
MPEG2: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
MP2: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
MP3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
AAC: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
AC3: No Preferred Filter set
TITLE 1 SOURCE FILES
Video: H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 1.mp4
Info: AVC - 4786 kbps - 1280x720 - DAR 16:9 - 50 fps (CFR) - Progressive - 59:03 minutes - 177152 frames
Audio 1: H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 1.mp4
Info: AAC LC - 320 kbps - VBR - 2 ch - 48000 Hz - 59:03 minutes (0 ms delay) - EN
[MediaInfoLib - v0.7.77]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ColorMatrix.dll")
Video = A2DVideoSource("H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 1.mp4", CacheFolder="C:\Users\BRIANA~1\AppData\Local\Temp" , VFR=false, FrameRateNum=50, FrameRateDen=1, FrameRate=50)
Audio = A2DAudioSource("H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 1.mp4", CacheFolder="C:\Users\BRIANA~1\AppData\Local\Temp" )
Video = Video.ColorMatrix(source=0,dest=2)
Video = Video.ConvertToYV12()
Video = Video.Spline16Resize(720,576)
Video = Video.SelectEven()
AudioDub(Video, Audio)
DIRECTSHOW AUDIO MIXER OPERATIONS:
No LAV Filters mixer ON/OFF adjustment required at runtime
START VIDEO ENCODING OPERATIONS
Video Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 1358.3 MB
Encoding Parameters: -ini "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1.m2v
*LOGFILE C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1.HCenc.log
*MAXBITRATE 9000
*BITRATE 3216
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX HCLOW
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*DBPATH C:\Users\BRIANA~1\AppData\Local\Temp
*WAIT 2
<10/09/2020 20:36:32>
END VIDEO ENCODING OPERATIONS
Video Source Filter: A2DSource (DirectShowSource)
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1.m2v (1359.2 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3218 kbps - 720x576 - DAR 16:9 - 25 fps - Progressive (TFF) - 59:03 minutes - 88576 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_1.ac3"
<10/09/2020 20:37:05>
END AUDIO ENCODING OPERATIONS (Track 1)
Audio Source Filter: A2DSource (DirectShowSource)
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_1.ac3 (81.1 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 59:03 minutes (0 ms delay)
DVD CHAPTERS CREATION OPERATIONS
Title 1 Input Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500
Title 1 Output Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_Chapters.txt (78 Byte)
<10/09/2020 20:37:06>
TITLE 2 SOURCE FILES
Video: H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House Of Assad - Episode 2.mp4
Info: AVC - 1997 kbps - 1280x720 - DAR 16:9 - 25 fps - Progressive - 59:12 minutes - 88800 frames
Audio 1: H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House Of Assad - Episode 2.mp4
Info: AAC LC - 128 kbps - CBR - 2 ch - 44100 Hz - 59:12 minutes (0 ms delay)
AVISYNTH SCRIPT
Video = A2DVideoSource("H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House Of Assad - Episode 2.mp4", CacheFolder="C:\Users\BRIANA~1\AppData\Local\Temp" , FrameRateNum=25, FrameRateDen=1, FrameRate=25)
Audio = A2DAudioSource("H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House Of Assad - Episode 2.mp4", CacheFolder="C:\Users\BRIANA~1\AppData\Local\Temp" )
Audio = Audio.SSRC(48000)
Target Video FileSize: 1361.8 MB
Encoding Parameters: -ini "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2.m2v
*LOGFILE C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2.HCenc.log
*MAXBITRATE 9000
*BITRATE 3216
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX HCLOW
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<10/09/2020 21:05:02>
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2.m2v (1362.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3218 kbps - 720x576 - DAR 16:9 - 25 fps - Progressive (TFF) - 59:12 minutes - 88801 frames
Wavi+Aften Parameters: "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_1.ac3"
<10/09/2020 21:06:44>
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_1.ac3 (81.3 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 59:12 minutes (0 ms delay)
Title 2 Input Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500
Title 2 Output Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_Chapters.txt (78 Byte)
TITLE 3 SOURCE FILES
Video: H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 3 - vlc.mp4
Info: AVC - 1604 kbps - 1280x720 - DAR 16:9 - 50 fps (CFR) - Progressive - 59:05 minutes - 177236 frames
Audio 1: H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 3 - vlc.mp4
Info: MPEG-1 Audio layer 2 - 128 kbps - CBR - 2 ch - 44100 Hz - 59:04 minutes (0 ms delay) - EN
AVISYNTH SCRIPT
Video = A2DVideoSource("H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 3 - vlc.mp4", CacheFolder="C:\Users\BRIANA~1\AppData\Local\Temp" , VFR=false, FrameRateNum=50, FrameRateDen=1, FrameRate=50)
Audio = A2DAudioSource("H:\Videos\TV programmes\A Dangerous Dynasty\A Dangerous Dynasty - House of Assad - Episode 3 - vlc.mp4", CacheFolder="C:\Users\BRIANA~1\AppData\Local\Temp" )
Target Video FileSize: 1359.1 MB
Encoding Parameters: -ini "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc.m2v
*LOGFILE C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc.HCenc.log
*MAXBITRATE 9000
*BITRATE 3216
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX HCLOW
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<10/09/2020 21:37:34>
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc.m2v (1359.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3218 kbps - 720x576 - DAR 16:9 - 25 fps - Progressive (TFF) - 59:05 minutes - 88618 frames
Wavi+Aften Parameters: "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_1.ac3"
<10/09/2020 21:39:15>
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_1.ac3 (81.1 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 59:05 minutes (0 ms delay)
Title 3 Input Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500
Title 3 Output Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_Chapters.txt (78 Byte)
START DVD MENU BUILDING OPERATIONS
DVD Menu settings:
Style: 0
Aspect Ratio: 1
Titles Format: 1
Template: Menu in Black
Max Titles Page: 12
Enable Play All: 1
Force Play All: 0
Background Audio: 0
Max Thumbs Row: 4
Thumb Image Source: 0
Thumb Frame Position: 10%
HL Frame Format: 0
HL Selection Color: 5
HL Play Color: 0
Menu Video BitRate: 6000 kbps
Motion Menu Duration: 15 seconds
Thumb Drop Shadow: 2
Play All Shadow: 2
Arrows Shadow: 0
<10/09/2020 21:39:19>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_MenuPage1.bmp (1.2 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_BatchMux.ini"
BatchMux ini file:
-bmlog "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_BatchMux.log"
-d "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1\VIDEO_TS"
-mxp "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_MuxMan.mxp"
-l "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_Palette.txt"
-v "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1.m2v"
-vidmode LB
-a1 "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_1.ac3"
-a1lang en
-cellfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_Chapters.txt"
-progfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_Chapters.txt"
-chapfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_01_A Dangerous Dynasty - House of Assad - Episode 1_Chapters.txt"
-SEG2v "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_1.ac3"
-SEG2a1lang en
-SEG2cellfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_Chapters.txt"
-SEG2progfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_Chapters.txt"
-SEG2chapfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_02_A Dangerous Dynasty - House Of Assad - Episode 2_Chapters.txt"
-SEG3v "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc.m2v"
-SEG3vidmode LB
-SEG3a1 "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_1.ac3"
-SEG3a1lang en
-SEG3cellfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_Chapters.txt"
-SEG3progfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_Chapters.txt"
-SEG3chapfr "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Title_03_A Dangerous Dynasty - House of Assad - Episode 3 - vlc_Chapters.txt"
-SEG4v "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_MenuPage1.bmp"
-SEG4vidmode LB
-SEG4s1 "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1_Menu.sst"
-SEG4s1dmode WIDE_LB
-SEG4hlmnu "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_MenuPage1_Buttons.mnu"
-SEG4hlcsm "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_HighlightScheme.csm
-hcn "C:\Users\BRIANA~1\AppData\Local\Temp\A Dangerous Dynasty_1_BatchMux.hcn"
<10/09/2020 21:45:11>
END DVD AUTHORING OPERATIONS
Created Folder: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1 (4431.1 MB)
CHECK DVD SIZE
DVD Folder (actual) Size: 4431.1 MB
vs Assets Size: 4326.5 MB -> OK
vs Estimated Size: 4449 MB -> 0.4% undersize
<10/09/2020 21:45:12>
START ISO IMAGE BUILDING OPERATIONS
ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1\VIDEO_TS" /dest "C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1.iso" /volumelabel "A Dangerous Dynasty" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
<10/09/2020 21:48:29>
END ISO IMAGE BUILDING OPERATIONS
Created File: C:\Users\Brian Admin\Videos\A Dangerous Dynasty_1.iso (4.3 GB)
AVStoDVD Project ended successfully.
Log file created by AVStoDVD Release 2.8.5
<>Last edited by br1anstorm; 12th Sep 2020 at 17:10.
Probably best to upgrade AVStpDVD to the latest 2.89 alpha; it's stable and has many fixes and improvements.
Or, if you want to put that off for now, go into preferences Avisynth tab and set FFMpegSource for video and audio
source filters. Save as default.
Now add just the problem mp4 and try it by itself. -
Lots of info for my tired eyes but am I seeing right that the Title 3 audio is 59:04 and the video is 59:05 ? I don't do much processing anymore but when I had the gradual sync drift you describe it's been due to uneven lengths.
<>There's not much to do but then I can't do much anyway. -
Thanks gll99... I had noticed that. A one-second difference. Would that result in the audio sync being adrift by 5-6 seconds (or more - I can't actually measure it) by the end of a 59-minute programme?
And if that disparity is the cause of the problem, how do I "stretch" the audio track to match the video at 59:05?
There are other differences too. For example, the first two titles/episodes have audio tracks which are "AAC LC" (whatever that is!) while title 3 audio is "MPEG-1 Audio layer 2".Last edited by br1anstorm; 13th Sep 2020 at 12:01.
You can check that LAV filters are actually being used.
Load the mp4 into AVStoDVD. At the top select codec/build directshow filters graph
I've seen situations where having mp2 in MKV/mp4 causes problems.
Still best, for this file, to use FFmpegsource as I mentioned earlier -
Well, thanks very much to everyone who has chipped in with suggestions. I think I have solved the problem, even if I don't quite understand the diagnosis of what was wrong.
I took davexnet's advice, and re-set the Avisynth settings in AVStoDVD from whatever the default was (I think it was A2Dsource?) so that both video and audio source filters were FFmpegsource instead.
I then made an ISO of just the problematic Episode 3, as a test run. When I checked the ISO using VLC, it played perfectly - no sync problem at all.
So, I then used AVStoDVD to create an ISO image containing all three episodes (as with the very first - problematic - DVD). I left the source filter settings on FFmpegsource. Created the ISO image, and checked it using VLC. It, too, played perfectly. No sync problem.
I have just burned that ISO to a disk. It, too, plays well all the way through. So - whatever the cause of the loss of sync, re-setting the AVStoDVD Avisynth settings seems to have done the trick.
It still mostly seems like witchcraft to me, but I am pleased that I have a DVD which has all the programme episodes complete and playing properly. Let's hope future projects are trouble-free.... -
Glad to hear it worked. If you've the inclination, also upgrade to the latest version, as I mentioned earlier -
many improvements, fixes and a lot of hard work went into it.
Directshowsource is known to have problems, it's not frame accurate amongst other things.
Another thing handled better in the new version
MP4 File Re-Sync Batch Conversion (Avidemux?)
By lplp in forum Video ConversionReplies: 1Last Post: 21st Sep 2019, 00:47 -
MP4 audio out of sync when streamed only
By Yonahinthewhale in forum Video ConversionReplies: 6Last Post: 4th Sep 2019, 21:17 -
New to this, trying to add audio tracks from DVD movie to .mp4 file
By Sentient0000 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2019, 08:21 -
Random audio/video sync problem with webcam recorded video
By TinoArts in forum Video ConversionReplies: 2Last Post: 3rd Aug 2016, 13:57 -
DVD to mp4/m4v to sync additional audio to the video... Settings advice?
By nobodyhome in forum DVD RippingReplies: 5Last Post: 12th May 2016, 15:28
