I have discovered that when I play my VCDs on my standalone DVD Player (Philips DVD762) and they go out of sync - often after a slight freeze - I can resync the audio by pressing the pause button, rewinding for a few seconds, pressing the pause button again and then pressing play.
This works and the audio comes into sync again.
I HAVE NO IDEA WHY THIS SHOULD WORK!
Can anyone explain?
Hi,
Did you have an explaination for this problem. I have the same thing with my DVD612. The anoying thing is that with every new clip on the CD you have to press the 'pause' button to get the the audio/video in synch again.
Hope you have some additional information.
NicoE -
buddymann- these vcd's with sync problems, do they contain mpg files created with powervcr 2? whenever i create vcd's with powervcr 2 mpg's i get exactly the same problems as you have experienced.
The mpg files are created with TMPGEnc - and I stopped using the new versions and have gone back to Beta 12a or 12b.
Movies downloaded and already converted to mpg usually run without a hitch - the out of sync phenomenom is mostly on my own conversions, but as I wrote, can usually be fixed by pause, rewind, pause and play. And I'm still no wiser as to why it works!
SOLVED: preview, out of sync subtitles behind Subtitle Workshop....
By bahjan in forum SubtitleReplies: 0Last Post: 10th Mar 2012, 05:27 -
ATSC Video, Sync - Solved
By sambat in forum Video ConversionReplies: 11Last Post: 21st Oct 2011, 12:12 -
solved
By SailorStar1 in forum Newbie / General discussionsReplies: 15Last Post: 10th Jul 2009, 07:09 -
Solved? (like Thanks!)
By lordsmurf in forum FeedbackReplies: 9Last Post: 14th Feb 2009, 21:15 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
