Hi.
I pretty often does screen captures of complex applications (office, websites, various technical applications etc but not gaming) for learning purposes.
Normally, I use Avidemux to trim and encode the videos. And most of the times, a couple of minutes of recording may take less than 4MB of space - that is very good compression.
Since the video mostly consists of still pictures where small parts are moving/changing I'm thinking - is there certain settings that may further increase compression ratio or retaining sharpness (small characters/icons) specific for this kind of source video ?
For x265 --tskip
https://x265.readthedocs.io/en/default/lossless.html#transform-skip
Also , longer GOP intervals (but this adversely affects seeking), more b-frames
If there are sections with no difference at all (no movement, static sequences), then VFR can help
Quality wise for sharpness of small icons, chroma subsampling can make a difference. YUV444 will be more clear than YUV420, but YUV444 will not be supported by as many scenarios (e.g. if you share on youtube, it will be converted to 420 anyways)
Most energy efficient settings for Potplayer
By Bernix in forum Software PlayingReplies: 0Last Post: 31st Dec 2017, 07:45 -
Video Conversion: from whatevver to x265 is not more efficient?
By Valmont in forum Newbie / General discussionsReplies: 10Last Post: 23rd Dec 2016, 18:28 -
Netflix Finds x265 20% More Efficient than VP9
By Baldrick in forum Latest Video NewsReplies: 12Last Post: 8th Sep 2016, 14:07 -
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 08:14 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 07:14
