Is there any program that will simply rip the audio from video, losslessly?
For years I used 'FreeVideotomp3Converter', assuming it was ripping the audio (I had it set to "original quality) but then to my horror I found out it was re-encoding audio - even changing the codec from AAC to mp3! What a piece of junk!
I've also just tried 'Pazera', but this program does the same - re-encodes rather than ripping the original audio file.
Is there anything that simply RIPS the original audio?
Results 1 to 10 of 10
Pretty much every video muxing/demuxing tool can extract the audio without reencoding. MkvToolNix, MkvExtractGUI, VLC, ffmpeg,..
A ffmpeg-based lossless demuxer GUI would be a good choice, if one exists. Avidemux may work (but it didn't auto-select the output extension in my test).
- ffmpeg command-line will transcode based on output extension by default !
- mkvtoolnix GUI wants to extract to .mka
- MkvExtractGUI only accepts .mkv input
- VLC has many issues including this one: https://forum.videohelp.com/threads/398562-Will-I-be-able-to-save-this-corrupted-MKV-f...-sad-history-( -
In that case, it is most unfortunate that this option is hidden away in menus and the interface makes no mention of extraction. There really ought to be a nice big button for this, and it should be the default setting, since most people would surely want to extract rather than convert.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
Extracting audio losslessly with ffmpeg or mkvextract
By Alexander24 in forum AudioReplies: 9Last Post: 23rd Aug 2019, 05:55 -
What is a good program for losslessly joining mp3 files without re-encoding
By imkira3 in forum EditingReplies: 4Last Post: 25th Jun 2019, 23:06 -
How do I rip videos from v.qq?
By Rex in forum Video Streaming DownloadingReplies: 12Last Post: 4th Nov 2018, 08:01 -
How can I rip videos from this particular website?
By aruwin in forum Video Streaming DownloadingReplies: 20Last Post: 27th Dec 2015, 03:09 -
How to rip from tenplay videos ?
By Joshua20 in forum Newbie / General discussionsReplies: 0Last Post: 18th Sep 2015, 12:47
