I have generally been happy with my HandBrake quality settings for ripping Blu-rays to MKV. However, there is one scene in one Blu-ray where the picture dissolves into kind of a fog, and apparently that type of video is had to compress well without it becoming blocky.
I'd like a way to encode that scene with a much higher bitrate/quality but keep the remainder of the movie at my normal settings.
I tried encoding Chapters 1-7 with my normal settings, and then Chapters 8-9 at much higher quality settings and merging them with MKVToolnixGUI, but the appended chapters come out totally corrupt somehow after appending, even though they are fine on their own.
I've confirmed that the dimensions and frame rates and everything else are identical between the "regular quality" and "high quality" videos I want to merge.
Is this something that isn't possible? Or am I just doing something wrong? Or is there a better way to accomplish this type of scene-specific/chapter-specific quality boost when making an MKV file?
Thanks!!
it's not possible to append segments with different encoding parameters in a single file.
You can use --zones to specify a range of frames where you 'd apply bitrate multipler. It's applied during a single encode, so there is nothing to append
The syntax in handbrake is slightly different than x264 or x265 CLI ; For example, if you wanted frames 1000 to 2000 to have a 2x multiplier, you'd enter in the advanced options
Code:zones=1000,2000,b=2
Giving a video file a higher average bitrate than it actually is?
By Chibi in forum EditingReplies: 4Last Post: 5th Sep 2017, 23:51 -
Converting an AAC Mono file to AAC Stereo, higher audio bitrate?
By brightmademedia in forum AudioReplies: 2Last Post: 17th Jun 2017, 10:41 -
Handbrake for higher res video? And odd bitrate....
By YeshyyyK in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2016, 11:51 -
Importing Chapter Menus/Chapter Markers in Xmedia Recode
By Alexp120 in forum Video ConversionReplies: 0Last Post: 29th Feb 2016, 18:37 -
Higher number of ReFrames = higher quality?
By ankutsa in forum Newbie / General discussionsReplies: 13Last Post: 8th Nov 2015, 18:08
