Hello everybody,
I hope that someone can help me. I have AVC (Any Video Converter) and AVC Professional (I don't see the difference between the two.) I have successfully burned some PAL video files to dvd as "dvd data files" using this program. My blu-ray player can successfully play data files as video and sound files. However, in other circumstances, I have failed to do so. I receive a "files corrupted" message on several of the files--and these are files that many others have had success with. There has also been instances where the video that gets burned is only one part of the video--like the first two minutes of the video.
Here is my procedure: I download the video from a torrent site (legal and unofficial music videos that aren't copyrighted). I then save them as an image file with IMGBurn. From there I add the image file to AVC (Any Video Converter). Then I burn it to a dvd. Half the time it works; it usually works on shorter videos that are less than an hour long.
I've heard things about .BUP files and stuff. Some of the video files don't have these files.
Here are some of the issues I encountered:
1) When I go to upload the image to AVC, I only see one aspect of the video - maybe a 10-minute segment- only displayed. It's not the whole video. So I consider this a failed attempt, and I don't know what I did wrong.
2) When I go to upload the image to AVC, I see the whole 90-minute video. I press "convert". After it converts, I try to burn it. It either only burns the audio or it says that files are corrupted.
3) It won't burn to the dvd because the file is too large; I don't understand this because I do have Dual-layer dvds and the file reads less 7GB.
Other program that I have that I don't user is "Trader's Little Helper" and "DVDfab"
I download this program AvsTODVD. I'm stuck at a screen that says something like: "1 Audio file with similar filename found" Please select up to 3. And then there's two boxes: ALL or NONE. When I click ALL nothing happens. When I click NONE nothing happens. As a result I click the x at the upper-right corner of that box. And then is says again "Warning...blah blah about PAL". I clicked no like davexnet said, but after I did so that whole process began again. I still can't get PAL video files to burn to a NTSC dvd. I did set up NTSC in my preferences.
Ya,post a text view,not a text file.
Menu creation advice needed, possibly with DVD-Styler
By Reddwarf4ever in forum Authoring (Blu-ray)Replies: 15Last Post: 8th Sep 2020, 04:46 -
Trouble Playing Pal Dvd's in PotPlayer
By OkamiDude in forum Software PlayingReplies: 2Last Post: 21st May 2020, 21:32 -
MPEG-4 Visual / AVC trouble
By Anvil2k12 in forum Video ConversionReplies: 4Last Post: 21st May 2016, 02:19 -
Newbie advice needed - Capturing PAL VHS
By Gameshow Host in forum Capturing and VCRReplies: 42Last Post: 28th Apr 2016, 11:49 -
Advice for DVD burning/formating
By WazaKrash in forum DVD RippingReplies: 9Last Post: 31st Oct 2015, 13:46
