Hi there
I have a problem. I have on my HDD a lot of Doctor Who videos from both the classic and new series. I am using Plex. I've renamed everything using FileBot so that Plex presumably recognizes everything. I also have them in two different folders, one for the old and one for the new and renamed them properly as well.
However, Plex only shows one folder and has the lot included in it, and it's also getting the old and new series mixed up. I've been told that one possible reason for this is wrong Metadata? Since I have so many Doctor Who videos on my HDD, I don't want to have to go through the whole lot of them individually to check the Metadata. I know that you can use Adobe Bridge to replace them, but I can't find anything on the net that specifically tells me how to batch remove all the metadata?
MKVToolNix has helped me in the past when removing metadata, but it doesn't come with any batch tool (that I'm aware of?) for mutiple files?
With mkvpropedit .. this works for me to erase everything in mkv file .. try
@echo off
FOR %%a in (*.mkv) DO "mkvpropedit.exe" -t global: --delete-attachment "1" --delete title --edit track:v1 --delete name --edit track:a1 --delete name --edit track:a2 --delete name --edit track: s1 --delete name "%%~na.mkv"
maybe there are unnecessary things ..責任者-MDX
MKV Batch Metadata Removal Tool - JMkvPropedit??
By BJ12 in forum Newbie / General discussionsReplies: 18Last Post: 13th Apr 2021, 20:18 -
How to batch copy metadata with ffmpeg?
By Pixelcruncher in forum ProgrammingReplies: 3Last Post: 19th Apr 2020, 10:57 -
ffmpeg: Extract Video and KLV Metadata
By leket in forum Newbie / General discussionsReplies: 2Last Post: 5th Sep 2018, 07:12 -
Metadata removal - tried the "normal methods", they didn't work
By jh443 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2016, 17:53 -
(HELP PLEASE) FFmpeg - Batch Remove metadata
By uppon2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jun 2016, 07:47
