I was using a Samsung SCL810 to digitize some Video 8 tapes. Everything was working fine until one night I left the camera on in playback mode (no tape loaded). Now it seems like everything works mechanically, but I am not getting any picture or sound, just snow. I have tried playing back multiple tapes, including ones that worked before.
Can the heads just suddenly be too dirty without any prior signs of trouble? Or did I burn something out by accidentally leaving the camera on overnight? Unplugging the camera for several hours doesn't change anything. I tried cleaning out the chamber with compressed air. I've ordered some 99.9% isopropyl alchohol for cleaning with chamois swabs, but in the meantime is there some other issue I can check? Thank you.
Does the camcorder display anything on TV without tape? like menu settings, OSD, input feed if it has inputs...etc
Yes, the menu and timer display just fine in the viewfinder, the lcd screen and on the laptop. The only issue is that no video or audio will play, the tape mechanism works but only plays snow.
Just clean the heads, possible condensation with some dirt.
Cleaned the heads with chamois swab and 99.9% isopropyl alchohol, no luck.
My guess is either the drum is not turning or the data path between the player/camera and the output circuit is broken (bad capacitors?). Don't know if it matters, but in camera mode there's no picture either. Maybe when I left the camcorder switched on overnight, it generated enough heat to fry an aged capacitor.
Either way, at this point the camcorder is junk, right? -
Sony Camcorder TRV815 Hi8 old tapes won't playback in camcorder
By Dforsythe in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2019, 17:21 -
Best way to view digitized analog tapes on modern TVs
By Christina in forum Newbie / General discussionsReplies: 7Last Post: 23rd Apr 2019, 22:31 -
Converting Hi8 analog tapes to digital
By mrittman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 26th Aug 2018, 14:58 -
analog Camcorder to digital trouble
By Billkjell in forum Capturing and VCRReplies: 6Last Post: 22nd Apr 2018, 04:30 -
Trying to see my tapes from the 90s! Are the tapes broken? Or my camcorder?
By melissa in forum Newbie / General discussionsReplies: 6Last Post: 3rd Sep 2017, 21:49
