Closed Thread
  1. hello,
    where can i to find a firmware for lg dvd dp132 and lg dvd dp132h? both are region 1 any help will be very appreciated, thanks.
    Mar 2008
    Was there ever a firmware update for this player?
  3. Thanks for your reply, I just wanted to change the region, I have tried all the fixes and none works on these dvd 2020 region 1, I tried a cd and it says check disc, I thought I could change the firmware, if there is one
    Mar 2008
    More than likely the hack worked on earlier models, then LG updated the firmware to close the door.
    Even if you found an earlier firmware do you have instructions on the update process?
    What was on the disk you got from eBay?
    canada
    eagle519-please do not open duplicate threads on the same subject,this thread is closed,continue here.
    https://forum.videohelp.com/threads/398658-lg-dp132-question#post2594001
