Was never sure about this setting, figured I'd finally ask.
I understand
- if I pick constant, and in the drop down say 30fps, it will be a constant 30fps.
-if I pick variable, the rate will go up/down where I need it more/less
But... if I click "Same as Source" does it ignore constant/variable? or do I have to click same as source and constant together?
Also... which is typically better to use?
I use to encode video with a set bitrate, but found that wasn't the best option in most cases and switched to constant quality H.265. Wondering what the best framerate would be. Up to now, I've been using what's in the attached image.
[Attachment 54760 - Click to enlarge]
Most videos have a constant framerate,only use variable framerate when you know that the video has that property.Using a set framerate is used for changing if you know wht the results will be like.
Multi framerate video problem
By killerteengohan in forum RestorationReplies: 4Last Post: 15th Mar 2020, 22:16 -
Remuxing variable framerate video?
By TBMNY in forum Video ConversionReplies: 5Last Post: 20th Jun 2018, 18:34 -
DVD Ripping using Vidcoder 4 hr. 39min. home video 7.84GB only 2 hrs. saved
By Studly in forum DVD RippingReplies: 5Last Post: 25th May 2016, 10:31 -
Need help working with video with variable framerate
By nfshp253 in forum EditingReplies: 8Last Post: 31st Jan 2016, 03:59 -
Video Encoding to 10 bit output using Vidcoder or Handbrake?
By kairukun in forum Video ConversionReplies: 2Last Post: 19th Sep 2015, 10:52
