Every distro I have ever seen over the last decade or so comes with ffmpeg pre-installed, the only difference is what build options are chosen. All Ubuntu, Fedora, Debian, Arch, Manjaro, Suse, you name it have it available, just open up a terminal and type ffmpeg and you will see that it's installed.
If you want to build a custom copy, download the latest source, extract the archive, go into the main folder, open a command prompt, type ./configure with whatever options you want, then type make and sudo make install.
Results 31 to 33 of 33
I'm building ffmpeg for myself regularly with almost everything enabled. Some dependencies are shared (dll) because of some issues. If you're okay with some dll's or if you don't want those dll's (kvazaar, fribidi, chromaprint, vulkan, glslang, opencl, openal, twolame, zeromq), I can build them for you.
I see Zeranoe's forum is now dead
By hydra3333 in forum Latest Video NewsReplies: 0Last Post: 23rd May 2020, 07:39 -
Alternative to Zeranoe's Build script
By MaverickTse in forum ProgrammingReplies: 1Last Post: 26th Jul 2017, 05:08 -
Elgato HD60 - Shows no video input after closing the program -
By ItsBill in forum Capturing and VCRReplies: 3Last Post: 13th Jun 2016, 23:49 -
Slysoft closing shop and Fengtao abandoning 4k Blu-ay
By Poppa_Meth in forum Latest Video NewsReplies: 3Last Post: 27th Feb 2016, 12:38
