I've been using this batch file to edit MKV files since last November, it doesn't seem to work anymore. Any help?
Code:dir/b/s *.mkv >list.txt for /F "delims=;" %%F in (list.txt) do "C:\Program Files\mkvtoolnix\mkvpropedit" "%%F" --edit info --set "title=%%~nF" del list.txt for %%a in (*.mkv) do "C:\Program Files\MKVToolNix\mkvmerge.exe" -o "tada\%%~a" --audio-tracks 1,3 --subtitle-tracks 6 --default-track 3 --default-track 6 "%%~a"
1. Any error messages? Log?
2. Which part is failing: mkvpropedit or mkvmerge?
3. Are all the tracks in the files in the expected order (--audio-tracks 1,3 --subtitle-tracks 6 --default-track 3) - check using: mkvmerge.exe -i "filename.mkv" (other programs may show a different order so are not necessarily helpful)
4. Reading/writing rights in the folder?
Easy way to use mkvtoolnix as batch help
By xonathan in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2023, 22:36 -
MKVToolnix Batch Merge Videos and Subtitles, Different Formats
By pumpysworld in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2018, 21:16 -
Batch header edit with MKVToolNix GUI?
By everapt in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2018, 11:07 -
Help for Batch Code MkvToolNix & Extract
By alloar in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2018, 15:42 -
Mkvtoolnix Batch Remove Audio OSX
By neostylez in forum Newbie / General discussionsReplies: 13Last Post: 27th Dec 2016, 08:42
